New '05 R53 Purple Haze owner
Old Nov 5, 2018 | 09:34 AM
  #101
audihere's Avatar
audihere
OK, great news. All the suspension parts are installed and West End Alignment got everything straightened out for me. Car handles really well, nice sharp cornering. We still need some lighter wheels (in the 15lb range) and non run flat tires.
I think some gold wheels will pop on this car but hesitant to pull the trigger. Plus they are 8" wide (don't come in 7") so some more alignment/spacer work will be necessary.
Old Nov 5, 2018 | 09:56 AM
  #102
ssean72's Avatar
ssean72
Originally Posted by audihere
We got an OBD programming cable from eBay (item# 252496444220) and it came with a thumb drive with EVERYTHING needed to code the car. Several auto installation programs that set everything up for doing the job. I was prepared to do a bunch of downloading and manual installation but we got lucky. The seller was also very responsive answering a few questions I had.
I really wanted to code the doors to unlock when key is removed as it's a pain to always have to unlock them with the switch or pull twice on the handle. We also coded the remotes to lock/unlock everything with one button press and auto up on the driver's window among a few other things.
what program did you get? I have the adapter but need a program so I can code the few things I am adding, never mind I found it
Old Nov 13, 2018 | 10:59 AM
  #103
Hecka's Avatar
Hecka
Woooo those are some niiiiiiice mods you got in there. Almost too good for an automatic! I'm just biased though.
Old Nov 15, 2018 | 11:30 AM
  #104
Getting there and still super clean. Like the sticker.
Old Nov 26, 2018 | 03:15 PM
  #105
audihere's Avatar
audihere
Ya, I don't know what it would take to convert to manual trans. Probably A LOT!
Old Nov 26, 2018 | 04:00 PM
  #106
audihere's Avatar
audihere
My son and I spent the whole Thanksgiving day installing a set of JCW type calipers (purchased from a fine member of NAM) and new discs etc. from WMW. Everything went pretty smoothly. We are really happy with the results.
Old Nov 29, 2018 | 12:45 PM
  #107
audihere's Avatar
audihere
Originally Posted by RB-MINI
Nice!
Which control arms are those? The look like Hotchkis, but all black.
Yes, WMW works sells them in all black.
Old Dec 11, 2018 | 11:03 AM
  #108
audihere's Avatar
audihere
The car had been making some serious intermittent racket for a few weeks and finally discovered the X-brace would rub the catalytic converter in some random conditions and vibrate the whole chassis. We ground the 2 spots of the brace where it was rubbing and repainted. So far, no racket
Old Dec 17, 2018 | 07:04 PM
  #109
audihere's Avatar
audihere
Was FINALLY able to acquire a used Rally Light wiring harness from a fine member of NAM. It's cut but I think we can make it work. Ordered the rest of the pieces we need. Hoping to install over Xmas break.
Old Dec 18, 2018 | 06:47 AM
  #110
Thanks for the update, yes the wire harness went NLA, But glad you found one.
Old Dec 18, 2018 | 09:21 AM
  #111
audihere's Avatar
audihere
Converted over to some wheel studs and nuts. Looks cool. A bit easier to take these S-"Lites" on and off too.
Old Dec 26, 2018 | 06:58 PM
  #112
Michael Jessop's Avatar
Michael Jessop
I am pretty much in awe of the work you have done on this car.
Old Dec 29, 2018 | 03:32 PM
  #113
Black-eyed-Purple-Mini S's Avatar
Miss mine since I sold her...RARE car and getting harder to find, Mine had the space grey and black interior...Does yours
Old Feb 28, 2019 | 03:50 PM
  #114
audihere's Avatar
audihere
Thanks! More pics coming soon. We were able to get the OEM rally light kit installed!
Old Feb 28, 2019 | 03:52 PM
  #115
audihere's Avatar
audihere
No, ours is black interior without the space gray. Anthracite plastics and headliner.
Old Feb 28, 2019 | 04:34 PM
  #116
Evlkarl's Avatar
Evlkarl
My compliments this Mini turned out awesome. You guys did a great job doing tasteful mods without going overboard.
Old Feb 28, 2019 | 05:28 PM
  #117
looks awesome, I had a '05 BEP as well, sold her, for a Nissan 350ZR...Even though I'm in another MINI today, always miss my purple.....
Old Feb 28, 2019 | 05:31 PM
  #118
well Hi there Boo....How are you? Daddy missed you
Old Mar 11, 2019 | 03:33 PM
  #119
audihere's Avatar
audihere
Well, still have to put wheel/tire on. Been flip flopping on which way to go.
Old Mar 25, 2019 | 02:03 PM
  #120
audihere's Avatar
audihere
Over Xmas break, my son and I installed a cobbled together OEM Rally Light Kit. As posted earlier, we found the hardest to acquire piece, the wiring harness from NAM member in used/cut condition. After checking it over, everything seemed OK, it had many of the supplementary electrical components still attached to it (LUCKY FOR US, BECAUSE ECS's KIT IS MISSING MUCH MORE THAN JUST THE WIRING HARNESS ITSELF AS STATED ON THEIR WEBSITE).
Here's the used harness.
Old Mar 25, 2019 | 02:04 PM
  #121
audihere's Avatar
audihere
Here's some pics of the relay wiring in case it helps anyone in the future DIY.
Old Mar 25, 2019 | 02:06 PM
  #122
audihere's Avatar
audihere
Pic of the wiring to trigger switch for DIY'ers
Old Mar 25, 2019 | 02:12 PM
  #123
audihere's Avatar
audihere
Luckily this fuse box and snorkel was still attached to my used harness. It's not included with ECS kit. Either is metal mounting bracket for it.
BUT, it seems like facelift R53 (or my car) is a little different than the instructions. There was already a small fuse box located in engine compartment where this is supposed to mount with metal bracket. We removed connectors and wound up just snapping them into existing box in open location. Luckily this worked because I was never able to locate a metal mounting bracket as shown in instructions.
Old Mar 25, 2019 | 02:15 PM
  #124
audihere's Avatar
audihere
Used some sheathing on the harness up to the light fixtures.
Old Mar 25, 2019 | 02:17 PM
  #125
audihere's Avatar
audihere
Cut hole in grommet. And had to re-connect all the main wires that were cut when the harness was removed from the donor vehicle.
