looking for info on hot climate coolant recommendations
Old Jul 2, 2016 | 11:26 AM
alisonlockwood's Avatar
alisonlockwood
We have a 2005 s in Africa and we need to buy coolant---please give us some suggestions on what to use for coolant! We just overheated! Thanks!
Old Jul 2, 2016 | 11:39 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
BMW blue color coolant or Prestone but only GREEN color.
Old Jul 2, 2016 | 11:40 AM
-=gRaY rAvEn=-
Moderator
Why did it overheat ?
Cracked coolant reservoir tank ?
Old Jul 2, 2016 | 12:08 PM
alisonlockwood
I will pose the question to my partner who is there with the car!
Old Jul 2, 2016 | 12:10 PM
alisonlockwood
What type of coolant should be put into the radiator?
Old Jul 2, 2016 | 05:24 PM
sevin's Avatar
sevin
Oem.
Old Jul 3, 2016 | 06:59 PM
-=gRaY rAvEn=-
Moderator
Refer to post #2 above. It doesn't have a fill cap on radiator as with traditional car. It has a pressurized overflow tank with a cap.
There are two bleeder areas to remove air in the system if it got low. You will need to remove that air in the system possibly.
One up front and a second near the bypass valve/throttle body area.
Old Jul 5, 2016 | 04:13 PM
Mini Mania's Avatar
Coolant
Here is some background information:
http://new.minimania.com/Cooling_Sys...R50_52_53_MINI
http://new.minimania.com/part/NMD760...reeze-1-Gallon
pezgoon
Jul 4, 2016 10:15 PM
E Man
Jul 2, 2016 09:32 AM
leftfield6
R55 :: Clubman Talk (2008+)
Jun 29, 2016 07:30 PM
SebZMonsteR
Jun 29, 2016 03:24 PM
shocku992
16
Jun 10, 2016 05:43 PM
