R56 Coolant flush
Old Jun 29, 2016 | 11:59 AM
E Man's Avatar
E Man
Coolant flush
My first attempt here at posting a thread, so bear with me. I have a 2012 Cooper S Hatchback. I would like to do a radiator flush and fluid change, I have the coolant and distilled water. Problem is I can't find the vent screw that you open for refilling. Does anyone have a picture or a link to one I can view. All I can find are the how too videos etc. of the older engine. I tried the search feature here, aparantly you have to be a lot smarter than I am to actually find anything.
Thanks.
Old Jun 29, 2016 | 12:34 PM
The radiator does not have a vent valve on the bottom to drain. Just unhook the bottom line and get a big pan to catch all the coolant. Then replace with new MINI Blue coolant and of course mix 50/50 with distilled water.
Put the hose back on and fill at the expansion tank cap. Then bleed, bleed , bleed/
https://www.ecstuning.com/Mini-2012-Cooper-R56-Base-Coupe-L4_1.6L_N16B16A/Engine/Cooling/Radiator/
Old Jun 29, 2016 | 01:00 PM
E Man's Avatar
E Man
Maybe I posed my question incorrectly, I can not find the "bleeder". I got in there with a flashlight and looked and looked. No luck. Where is the darn thing?
Old Jun 29, 2016 | 01:12 PM
https://www.northamericanmotoring.co...rmostat-6.html
On the thermostat housing on the driver side on the engine, its that hex nut with the phillips head
Old Jun 29, 2016 | 01:35 PM
E Man's Avatar
E Man
Great, thank you. I will search again and look for that. I imagine it's probably hiding in there under things, but I'll find it.
Old Jun 29, 2016 | 01:48 PM
Welcome, yea its a little down in there beside the engine cylinder head.
Old Jun 29, 2016 | 04:29 PM
E Man's Avatar
E Man
Well I went and tried again, still not finding it. Maybe I need to take off the fresh air tube so I can get a better look. I assume that it is facing up?
Or just bite the bullit and take it to a shop.
Old Jun 29, 2016 | 08:24 PM
renchjeep's Avatar
renchjeep
I was never able to find the bleeder screw on my 2011 MCS. If you find it, post a pic, if you can get one.
Old Jun 30, 2016 | 07:45 AM
Sorry, Forgot you are the 2012 Cooper ( NON S ) 6/2010 to 3/2012 whom did not have the newest conversion thermostat housing , when MINI changed things up.
https://www.northamericanmotoring.co...mp-sensor.html
https://www.northamericanmotoring.co...lant-leak.html
If i remember right the bleeder comes out at an angle.
Old Jul 2, 2016 | 09:32 AM
E Man's Avatar
E Man
My car is an S model. I gave up though, can't locate it. I'm going to drive up to a mini shop and see if they will show me where the darn thing is.
Mrdi
25
Oct 20, 2016 06:21 PM
AKRAPOVIC_Jurrian
Apr 20, 2016 10:05 AM
1004ron
Mar 22, 2016 09:39 AM
