R53 automatic Trans question
Old Apr 19, 2016 | 01:14 PM
speedman's Avatar
speedman
I have followed the tech article posted on pelicanparts.com showing how to drain and refill the trans in my R53. My question is if the car is on level ground and you remove the inspection plug should any fluid come out. I thought the level is controlled by the overflow pipe and very little fluid should come out. My car drains almost 1-1/2 quarts before it stops when the inspection plug is removed. I am wondering if the previous own may have over filled the trans in the process of a fluid change
Old Apr 26, 2016 | 04:20 PM
Mini Mania's Avatar
R53 Automatic Trans
Hi Speedman!
Based on factory instructions, it appears this transmission was over-filled. However, the level needs to be checked:
1. static, with engine off
2. engine at idle
3. shift from park to drive twice, then back to park
4. with engine at operating temperature
Please let us know if this helps!
Old May 10, 2016 | 04:46 PM
Bearybee's Avatar
Bearybee
I recently purchased an 06 R53 Automatic. I replaced the transferfluid with Amsoil and I had 2 qts come out on level ground. I believe that at a certain temp, it is possible that the trans fluid is at a different level. I replaced exactly with the amount I put in.
thinkMINI
Detailing 101
27
Feb 22, 2018 04:06 PM
AFN704
Apr 6, 2016 07:49 AM
Frixos
Apr 3, 2016 06:12 PM
SqAAAWWW
Mar 25, 2016 05:10 AM
camptown
Mar 22, 2016 07:39 PM
