2007 Mini won't start
Old Mar 8, 2012 | 09:18 PM
sbeaucha's Avatar
sbeaucha
Our 2007 Mini Cooper S just stopped starting today. The dealership telephonically told me to jump the car. I had someone do this but it still would not start. Called the dealer back and talked to a mechanic. He said the battery is original but needs to be replaced due to it's age. That is all that should be needed.
I had the battery replaced with a new one. Still could not get the mini to start. I have now seen how the clutch has a switch that may not be working well and can be fixed with a zip tie. I will give this a shot tomorrow before having the car towed 300 miles to be fixed.
Old Mar 8, 2012 | 09:42 PM
Boodro's Avatar
Boodro
Do you have power to all electronics? Is the starter turning? Keep us updated
Old Mar 9, 2012 | 05:38 AM
sLy201's Avatar
sLy201
hey welcome and sorry to hear about your problems on the MINI ... might want to post this in the appropriate area to get more feedback from people ... this is sorta the welcome page and not too many ppl check this
Old Mar 9, 2012 | 07:33 AM
Purpleoctopus's Avatar
Purpleoctopus
This exact same thing happened to my 2007 Mini right after I got it 2 weeks ago. I thought it was a battery too, and got that switched out. That did not help it. Then I finally got it to a Mini dealership to diagnose and they said it had an electrical short in the starter. They put a new starter in it and it is good as new! Is it cranking over at all? Slowly?
Old Mar 9, 2012 | 09:28 PM
sbeaucha's Avatar
sbeaucha
OK I cannot believe how simple the fix was. 142 dollars for a battery and install in a parking lot when all that was needed took a piece of packing tape to fix. The sensor on the cluthch piston was off. I taped it back in place and good to go. It started right up. I have since put a zip tie on it as well to make sure it stays put.
09R56
Nov 16, 2022 10:49 AM
SosoMINI
Nov 22, 2015 03:17 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
jrezzo
Aug 9, 2015 10:32 PM
tippin
Aug 5, 2015 08:43 AM
