Convertible top stuck "almost" closed
Old Jun 21, 2011 | 06:33 PM
Alex05738's Avatar
Alex05738
My 05 convertible mini top got stuck on it's way back into place because it came down short in the closing process. Now it will not go forward or backward. I am not sure what to do about it to get the top closed and I am not sure if I should risk it again. Please help.
Old Jun 22, 2011 | 09:27 AM
Not4no1's Avatar
Not4no1
A picture is worth a thousand words.
Where did it stop? Did the front latches catch?
There is a way to operate your top & the instructions are in the manual.
If it is latched, but the sunroof won't close, there is a mid-roof motor that you can crank. (crank is under the back seat)
If it isn't latched, there is an access in the boot that lets you manually control the rest of the roof.
I hope that helped...or at least gave you a good starting point.
Good luck!
Old Jun 22, 2011 | 10:38 AM
John_B's Avatar
John_B
Mine kept doing this until I replaced the faulty switch on the "trunk" cover thing. You may look into that to see if it got pulled up and let the switch off.
woodstudio
Mar 15, 2020 08:28 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Aug 19, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
dchang0
Aug 10, 2015 03:37 PM
