OIL PAN BOLT ??????
Old Sep 1, 2009 | 05:31 AM
whitenight's Avatar
whitenight
OIL PAN BOLT ??????
is there something special that i need to know on oil pan drain bolt on 03 mc s. ????
or is mine just seized to where i need to drill it out ??
Old Sep 1, 2009 | 05:57 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Not really, just use a 1/2" socket or box wrench and not the metric wrench....it fits tighter using the 1/2 inch on the bolt corners and will lessen the chance of stripping the head.
Sometimes these plugs are put on with impact wrenches at Jiffy lube type places....so they need to be heated up slightly with a torch and then removed.
And make sure you have a new one on hand before removing, you dont want to put that old one back on.
Old Sep 1, 2009 | 06:23 AM
Martin Brenneke's Avatar
Martin Brenneke
Get a Fumoto drain valve and you won't have this problem. you can google it and find the right size for your Mini.
Old Sep 1, 2009 | 05:06 PM
whitenight's Avatar
whitenight
thanks for the heads up. i almost destroyed it all but not off yet. dealer here i come
Old Sep 1, 2009 | 05:15 PM
whitenight's Avatar
whitenight
HOOVER DAM!!! you guys are full of good ideas today
Etrain
16
Aug 5, 2024 04:37 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
minipopkart
Aug 13, 2015 05:22 AM
