15% pulley
Old Aug 10, 2009 | 02:35 PM
jimbuckley2's Avatar
jimbuckley2
15% pulley
Hi, All
I just had the fun of visiting MITM this last weekend. Ended up with the first mod to my 02 MCS -- a 15% pulley installed by the fine guys from Way Motor Works. It really has made a nice difference in drivebility. It now seems like the gas pedal and the engine are working together rather than there being some lag time and starts from a stop are so much better (no need to rev the engine extra just to do a routine start from a stop sign). Highly recommend this mod to anyone that is thinking about it.
Old Aug 10, 2009 | 02:46 PM
mbu's Avatar
mbu
...a "15% pulley"...
Jim,
Care to elaborate a little on what that is for us "not so educated" new mini owners?
Thanks...
Old Aug 10, 2009 | 02:49 PM
daflake's Avatar
daflake
Smaller pulley on the super charger to generate more boost. I have a 17% myself. Great mod!
Old Aug 10, 2009 | 02:57 PM
jimbuckley2
15% pulley
I, too, am what would be called an uneducated owner in many ways. As the previous response indicated it is a smaller pulley that replaces the stock pulley on the supercharger. Needless to say, the smaller pulley will make the supercharger turn a little faster -- hence more air and boost to the engine. From what little I learned, 15% is the mildest size with basically no worries and something like a 19% is wilder and can possibly cause future maintenance issues. But most of this is way beyond my knowledge, too. I just know that I am very pleased the the improved performance with no noticable down sides.
Old Aug 10, 2009 | 08:25 PM
mbu's Avatar
mbu
Hmmmm...this "improvement" doesn't make much sense to me.
I thought turbo design involves balancing exhaust gas flow with compressor air flow volume. Add to this equation shaft speed, shaft weight, compressor and turbine housing flows and turbine wheel tip speeds . What about inlet and exhaust cam design, exhaust primary and secondary pulsed extractor lengths, variable turbo inlets and wastegates!
Seems to me the "improvement" just threw the original design parameters out the window.
Old Aug 10, 2009 | 09:13 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I'm so happy we could help.
As for mbu making sense, His car is supercharged not turbo charged. So putting a smaller pulley on the supercharger allowed him to gain a few pounds of boost and several HP. It was a small amount of boost so it hasn't hurt anything else.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Aug 11, 2009 | 06:43 AM
jimbuckley2
Thanks, Waylen. Basically what I was going to say. What MBU said was right on for the newer engines, but the earlier engines, like mine, using a supercharger, while trying to accomplish the same purpose used different components that worked differently.
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
