1st GearNew members: make an initial post and introduce yourself as you shift from Neutral to First Gear. Current members: meet some of the new members.
Has anyone ever had trouble with 1st gear? I occasionally have trouble getting it into 1st. Most of the time it is fine, but sometimes it won't engage all the way and just stops at that first "bump", and other times it grinds like the clutch isn't all the way in, when the clutch is all the way to the floor.
Maybe my Mini just likes to go fast...1st gear is just too slow for her
minigirl78 , it could be the first signs of a problem with the clutch hydraulics .
Check the fluid level . If it is full it is pushing past the seals internally in one of the cylinders .
If it were a clutch problem It wouldn't be limited to first gear. It could be a pilot bearing but probably the syncro's. Have you tried starting in 2nd and seeing if it has the same problem?
Definitely sounds like a syncro issue. My old MX-3 had this problem and rather than fix it I just let off of the clutch ever so slightly to get it to engage easily. Worked for me but if your car is under warranty I'd make mini fix it.
