Where is it/am I looking at the right thing???
Old Aug 31, 2007 | 12:29 PM
Knee Dragger's Avatar
Knee Dragger
Hi, pretty new with the forum and with the car, 07 S. I've been on before with cruise control and oil changes, thanks for the responses on those threads. What I've got now is, I'm going to change my oil filter and add a quart. I'm about 130 miles from my dealer and am a little nervous running 15K between changes, I've got a little over 6K on the car now. I got looking under the car and under the hood, now, I'm fairly mechanically inclined, but was having a hard time finding what I thought would be the oil filter. Under the hood looking down past the radiator recovery tank to the left is an item that looks like it could be the filter. It is fairly big in dia. and has what looks to be a nut on the end, but looks to be plastic?? Is this in fact the oil filter housing?? And, if this is it, what size is the nut?
Steve
Old Sep 1, 2007 | 07:00 AM
SteelersFan's Avatar
SteelersFan
Here's a very good DIY oil change thread. It should anwer all your questions. Good luck!
Old Sep 1, 2007 | 09:31 AM
Knee Dragger
SteelersFan,
Thanks!! Very good thread, lots of information that I needed, now, while I'm there, I think I'll change the oil completely instead of just the filter and a quart. I'm a little nervous about going 15K miles between oil changes, especially with a turbo car.
Steve
Old Sep 1, 2007 | 12:01 PM
SteelersFan
Originally Posted by Knee Dragger
SteelersFan,
Steve
You're welcome. Yes, going 15k between oil changes *seems* excessive. There has been A LOT of discussion on this. Do a search and you'll see what I mean.
Old Sep 1, 2007 | 06:22 PM
Knee Dragger
Got done with my oil change, not too bad of a job. I did find something that I do think should be noted on Z3Bum's procedure. The oil drain plug is not a T50 Torx, it's an 8mm allen. I don't think that I would use the Torx bit to loosen this plug, especially if it's really tight, you might strip out the hole. It did work for me, but after finding that it is an allen or internal hex, that's what I'm going to use after this.
patsum
26
May 29, 2021 06:29 PM
riff42
Sep 22, 2015 03:07 PM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
