Suspension Mild heart attack ...... quoted $1200 for lowering springs and sway bar install
Called a local independent Mini shop and they quoted me $1200 to install lowering springs and a rear sway bar on my 2016 Mini. Said it was going to be 5+hrs.
That seems really...... Ok, Frigging really expensive.
Anybody want to come to Minneapolis and install some stuff for me .......... not paying you $1200 though
This was a tuning shop, not a mini dealer but rather an independent garage that works on minis, bmws, vw etc...
Changing springs isn't really that bad, basic hand tools you can get it done in a day. Rent some spring compressors from your local parts store. Make sure you get the strut style compressors not the internal compressors.
I can't imagine a rear sway bar being any harder on a 2016 than an older car either.
Inde shops use a program to determine mod costs going by recommended replacement cost of the part using "book hours" for estimates. And since the car is more BMW than ever, that could be a factor in higher costs. Did that include an alignment too ? Did they mention if removal of rear sub-frame is necessary for bar install, as with the R56.
Trying to picture the underside of rear suspension, but not sure.
My indi tech changed the suspension including swapping springs and sway bar in a little over 2 hours on my R56. He quoted me $100 per corner to change springs and is gonna include RSB install on my F56.
Keep shopping around. Even figuring 5 hours labor, those bandits are charging over $200 an hour! Now, if they were supplying the parts and alignment that would make more sense.
Yes, we used AllData at the dealership and the indy shop I worked at for getting times on doing repairs, but if/when we knew it could take way less we wouldn't quote times from AllData. For coil overs we charged $450, where another indy shop in our area charged upwards of $1200 for coils alone. For Gen2 MINI's it should take about 1.5 hours for a rear sway bar install for the average DIY'er, so I'd assume it'll be close to that. I think you should shop around and get quotes from other shops. Otherwise, if you think you can tackle the job yourself I'm sure plenty of Gen3 MINI owners would appreciate a DIY.
888.280.7799 | 6am - 5pm PST
I have lowered all my own cars including my new JCW CM. My averse time for springs is 1.5 hours and once I got it down to 30minutes. Coilovers take longer, maybe 3 hours and and 30 minutes for a rear sway.
Average spring only install should be $275 and $50 for the sway. BTW on all the Mini's I have done, I never needed a spring compressor, there isn't that much tension
mQubed Motorsport, Manic Tuning Dealer
Craigslists!
ultrahuck
03-03-2016 05:37 AM
03-01-2016 04:44 PM
03-01-2016 12:24 PM
