Mini Cooper Turbo Additive Reinzoadd 20ml For Priming New Turbo's
Old Mar 1, 2016 | 12:24 PM
Mini Mania's Avatar
Part No: G2NME2899
Your Price $16.50
Protect your Turbo during initial installation with Reinzoadd which forms a heavy-duty lubricating film on all surfaces of the turbocharger to reduce friction and wear – with ideal properties for initial startup. 20ml tube.
Prior to initial operation the oil bore must be completely filled to prevent the turbocharger from running dry. REINZOADD the fully synthetic high performance lubricant forms a highly durable lubricating fi lm on all frictional and sliding surfaces to reduce friction and wear – with optimal emergency lubrication features and for an extremely long life.
Start-up trouble after installing turbochargers is now a thing of the past. Dana offers a highly dependable additive for initial turbocharger fillings: the synthetic high-performance REINZOADD lubricant. REINZOADD provides a smooth start after the replacement thanks to a combination of additional ingredients and MoS2.
During normal operation, the turbocharger is integrated into the lubrication circuit and is constantly rinsed with oil – but after it’s been replaced, it starts out dry. Only once the engine has been started does the lubrication circuit build up the necessary pressure to fill the turbocharger with oil – but there’s a delay. And this critical dry phase is precisely what REINZOADD is there for to bridge. It is essential to fill up the turbocharger before the first compression takes place. Otherwise, the turbocharger will run hot and cause irreparable damage – or even total destruction – to the engine.
REINZOADD uses the solid lubricant MoS2 to form a heavy-duty lubricating film on all surfaces of the turbocharger to reduce friction and wear – with ideal properties for emergency operation. The turbocharger is ready to start right away.
The Dana turbo experts recommend using REINZOADD every time a turbocharger is installed – for all designs from conventional turbochargers to ones with variable turbine geometry.
Benefits of REINZOADD lubricant
  • A tested additive for initial turbocharger filling which has proven itself in daily use at the shop
  • An effective combination of additional ingredients and MoS2
  • Allows you to start up the turbocharger safely right after installation
  • Reduces friction and wear
  • Improves turbochargers’ emergency operation properties and extends their service lives
fast_eddy
Oct 2, 2022 01:55 PM
tchain
Feb 19, 2018 06:10 PM
mrcharlesiv
Jan 30, 2016 06:59 PM
bajcw
Test Forum
Jan 21, 2016 03:11 PM
mini_mike237
Jan 15, 2016 12:16 PM
