2008 MC Heater Problem
Well, I searched for awhile and couldn't find a thread on this heater issue. I think it will really be a trip to the dealer, but . . .
A friend has a 2008 MINI Cooper with auto transmission. When she starts it up and lets the MINI warm up to temperature, the heater will only blow cold air. The engine is at temperature and the cooling fan is even running now and then. Does the same in AUTO (automatic climate control) or manually. Same is true of the windshield defroster. As soon as she pulls away and heads down the road, the heat comes as if all is fine. If she stops at a traffic light, the air goes cold again until the light changes and she pulls away. Sounded odd, but I took it for a ride and it did exactly that.
I checked the coolant level which was slightly low, but adding a little didn't help. I'd say there's air in the heater lines or its a faulty thermostat, but it's like the MINI knows when the car is in motion and gives up heat.
As posted in one thread, the OBC and software are intensive and probably the culprit.
Anyone experiencing this heater problem?
Moderator
It sounds like the problem that I had with an old 528e....that was the heater control valve, which was a well known problem with that model. I'm sure that the HCV is computer controlled in our Mini's, but the effect might be the same if the valve is faulty. Good luck and be sure and post what you find!
I have a 2008 MC and I think I am some of the same issues. I've noticed this week that I did not really have any warm air blowing. I changed the setting to recirculating, still the same. As I travel, it seems warmer, but it is not comfortable for much of the ride. VERY different from my '04 Mini.
The manual says not to "warm up" the engine. I've noticed that at first idle if you have Auto CC on it will be cold air, but my engine is cold, so I expect it. It warms up very quickly once I start moving. Try driving within 20 seconds of start and see how fast it gets warm. I imagine the heater core is locked out until the engine runs in drive for a short period.
Had the same problem with my 09 S, and just got it back from the dealer today. It had set a code (no CEL though) and the story I got from them was that there was a service bulletin issued for this problem. To resolve it, they say they flushed the cooling system and followed a revised fill process to remove air pockets that had formed, which caused the problem originally.
I have to say, while I'm not on board with some of the other things that the dealer is telling me, this did sound right. The problem felt exactly like I have had in other (much older) cars where air got into the system and kept the heater core from consistently providing heat.
Okay, here is the solution. I found the bleeder screws for the coolant, one near the radiator and one just behind the engine on the hose leading to the heater core. topped up the radiator and opened the valves until water came out. Started it up and ran it a while and repeated the process. I ended up adding about a pint of coolant until there was no more air. Heat works fine now...
Thought I would post, as this was one of the results when I was searching for no heat.
Wife's car is a 2007 MINI Cooper S at over 80K miles, and she finally mentioned she had no heat. Unfortunately, we blew threw our MINI's warranty in just over two years (wife's 50+ mile daily commute). So I checked to be sure it wasn't something I could take care of myself, or if I needed to drop a lot of money, and then perhaps make a trip to a non-dealer location.
Ultimately checked coolant level, which was low. Topped her off and heat came back after a day. Already had service scheduled for a state inspection, so asked them to check while it was there. Dealer called, and indicated they found the temperature sensor to be faulty, and a leak at the o-ring as well. It's gonna be around $150 to replace both. Oh well, needed the 60K flush anyways I guess, and this explains where the coolant went!
Just thought I would add to anyone that was searching. Check coolant - if low, add and heat will be back shortly, but also look for where your leak is. If not, try to bleed as mentioned above. If neither, keep searching I guess!
Thanks.
Thanks.
Coolant
Here's the procedure when draining and refilling, and it makes note of the previously mentioned bleeder screws
http://new.minimania.com/Cooling_Sys...R50_52_53_MINI
BRracing
12-22-2015 09:25 AM
sdotbailey
R55 :: Clubman Talk (2008+)
09-16-2015 09:03 AM
