Interior/Exterior HK Door Rattle Fix (Simple)
Old Jun 17, 2004 | 01:49 PM
jbing's Avatar
jbing
HK Door Rattle Fix (Simple & with Pictures NOW!!!)
Today I fixed my passenger side door rattle using 2" wide 3M Micropore medical tape.
CLICK ON THUMBNAILS TO VIEW PICTURES AT FULL SIZE!!!
As I have read this is a very common problem with the HK Stereo and speakers. I took the thin tape and cut it into strips about 1/2" wide and 8" long and then made six stacks, four layers thick.
Apply two stacks of tape, on top of each other, along the straight, bottom edge of the door panel below the speaker cover.
Next, place two more stacks of tape on the rounded corner edge.
Finally, place the last two stacks of tape on the straight edge leading up to the top of the door panel.
Here is what the cloth tape looks like on the visible edge of the door. Make sure to just barely roll the edge of the tape over onto the colored part of the door panel. This is a pic of the vertical and curved part of the door panel.
The cloth tape acts as a spacer to push the door panel away from the door frame without rubbing the paint off. It creates just enough tension to hold the door panel tight without allowing it to vibrate against the door frame.
Finally I decided to place short pieces of felt between the speaker grill and the door panel to damen any vibrations that might happen if the speaker grill wasn't applied tightly at the factory.
Have fun blaring the tunes rattle free with this simple fix!!!
Jason
Old Jun 18, 2004 | 03:38 PM
jbing's Avatar
jbing
Pictures for my HK Door Rattle Fix have been posted. This truly was a simple fix for that damn annoying rattle that is so common to the HK Sound System.
Cheers,
Jason
Old Feb 9, 2005 | 04:20 PM
jzlemon's Avatar
jzlemon
Thanks jbing. I just tried this and it worked like a charm. I substituted First Aid Secure-Comfort Cloth Tape (available at Walmart).
Old Feb 12, 2005 | 02:55 AM
Darkness's Avatar
Darkness
I found that hitting the speaker grill repeatedly will fix the problem. It always comes back though
Old Feb 12, 2005 | 06:22 AM
rmorin49's Avatar
rmorin49
Any tips to remove the panels?
Old Feb 16, 2005 | 07:52 AM
jzlemon's Avatar
jzlemon
Here's the info I used. http://www.mini2.com/forum/faq.php?f...aq_faq_removal. There is a section on door panels.
You really have to pry at first, but the panel does come off with no harm done.
Old Feb 16, 2005 | 10:13 AM
E1Designs's Avatar
E1Designs
So which one do I follow.........
http://www.jwardell.com/mini/hkdoor.html
Old Feb 16, 2005 | 10:17 AM
NoDak Pat's Avatar
NoDak Pat
Thanks Jason!!
Old Feb 16, 2005 | 11:42 AM
kaelaria's Avatar
kaelaria
Have any of you just tried wedging something under the corner of the panel? Like fold a business card a few times and squeeze it in there? If it's just the panel hitting the door causing the noise this will prove it.
All these fix pages do the same thing, and I don't see why you even need to remove the panel. I would just pry the panel up a little bit and slide some felt under if the pry test works. If the noise is coming from deeper in the panel, not just the edge, I guess it has to come off. I just haven't seen anyone say they tried this first.
alistaircookie
Oct 8, 2015 10:52 AM
Drivetrain Products
Aug 27, 2015 12:25 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
