Suspension Lowering the R56
Lowering the R56
There has been a lot of talk as to not being able to lower the R-56 to an acceptable amount so we had to give it a shot. Here is our new R&D car on the new coil overs and stock 16 inch wheels with the 195 / 55 series tires . At this stage the car drives fine, doesn't rub and can still take a railroad crossing at speed. The interesting part is that we still haven't gone as low as it can. We have a 17 inch wheel set to go on the car with 215/40 series which will have the same overall diameter of the set up on the car now so the look will be the same but the handling should be improved. More to come.
Randy
M7 Tuning
How low do you want to go ?
Randy
M7 Tuning
Very, very nice!! I was just talking to Peter the other day about you guys lowering it on the coilovers. Thanks for posting the pics, Randy. Looks a whole lot better than factory 4X4 option.
Randy
M7 Tuning
Any chance of removing the bolt-on black plastic strip of the front (lowest part of the car)? I wonder what that is for anyway.
We think we are about a 2 inch drop at this time . We just put the new wheels and 40 series tires on it and in a line of other minis the roof level was the lowest of them all. Pretty damn amazing . That lower plastic section could be removed but we have heard that it helps prevent lift of the front end at high speeds. It looks easy enough to remove and replace for an experiment in any event .
Randy
M7 Tuning
Randy
M7 Tuning
Randy the car looked awesome last night! You mentioned you were putting the rear control arms on today. Have you? do you notice much of a difference?
Bryan (the other R56 last night)
We are taking the car to H-sport for the entire ball of wax tomorrow. Corner balance, end links , sway bars and rear control arms will be taken care of then . We will also be doing some preliminary work on some new items as well. We have an appointment with a automotive writer for a test session this weekend for both cars so we need to get it dialed in FAST
Randy
M7 Tuning
loop4re7
Oct 5, 2015 09:53 PM
Aug 19, 2015 12:51 PM
