FS:: Works Bell Billet Steering Wheel Hub
Old 08-25-2015, 10:36 PM
barnoun's Avatar
barnoun
barnoun is offline
Category: Interior
Price: $125
Location (Region): NorCal
Selling my Works Bell Billet Aluminum steering wheel hub. Originally intended for R53, but I modified a hole in the back so it fits the R56 perfectly. Turn signals work just like stock. It's a short hub so the wheel ends up about 2 inches away from the turn signals if you use a flat wheel. Works very well with a dished wheel.
It's in excellent condition and includes everything necessary for you to install a MOMO or Nardi wheel onto your R56, including a horn with the included wires.
All you have to do is turn off the airbag with NCS Expert (competition use only!)
HUB IS SOLD!
Attached Thumbnails Works Bell Billet Steering Wheel Hub-img_0441.jpg   Works Bell Billet Steering Wheel Hub-img_0433-2-.jpg   Works Bell Billet Steering Wheel Hub-img_0431-2-.jpg   Works Bell Billet Steering Wheel Hub-img_20140320_115714.jpg
Old 08-27-2015, 08:11 PM
barnoun's Avatar
barnoun
barnoun is offline
bump
Old 08-28-2015, 05:34 AM
mishanja's Avatar
mishanja
mishanja is offline
you mentioned it was intended for R53, so I presume it will work for R53 as well?
Old 08-28-2015, 10:27 PM
barnoun's Avatar
barnoun
barnoun is offline
It should still work on the R53. I enlarged the hole on the lower portion of the hub to use the hub on the R56. I'm not sure if the turn signal canceling function will be affected now that the hole is larger since the R53 has a smaller nub than the R56.
Old 08-30-2015, 07:56 PM
barnoun's Avatar
barnoun
barnoun is offline
bump
Old 09-03-2015, 11:03 PM
barnoun's Avatar
barnoun
barnoun is offline
bump
Old 09-08-2015, 09:11 PM
barnoun's Avatar
barnoun
barnoun is offline
bump
Old 09-12-2015, 10:20 AM
barnoun's Avatar
barnoun
barnoun is offline
bump
Old 09-20-2015, 09:09 AM
barnoun's Avatar
barnoun
barnoun is offline
$125 takes it.
Old 09-21-2015, 04:38 PM
mishanja's Avatar
mishanja
mishanja is offline
Originally Posted by barnoun
$125 takes it.
$100?? It's a little lower than you wanted, but you not sure if canceling will work on r53 now that you have modified it?
Old 09-21-2015, 07:33 PM
barnoun's Avatar
barnoun
barnoun is offline
Currently pending sale, I'll update here if it doesn't get sold.
Old 09-21-2015, 09:43 PM
barnoun's Avatar
barnoun
barnoun is offline
Sold.
Old 03-08-2018, 12:01 PM
ksminiman's Avatar
ksminiman
ksminiman is offline
I am mainly interested in the tsc/dsc system. Dsc on these cars never fully deactivates. Abs only helps if you do not lock the tires under braking. Abs benefits are for another discussion though.
Old 09-17-2018, 05:04 PM
Timbo14's Avatar
Timbo14
Timbo14 is offline
17x7.5 Hyper Black on Pure Silver.
penguinhomey
38
07-07-2019 09:24 PM
12-23-2015 10:36 AM
nomar116
08-12-2015 05:24 PM
MES11
Navigation and Audio
08-06-2015 08:52 AM
Quick Reply: FS:: Works Bell Billet Steering Wheel Hub
