R56 New engine installed and running... now there is a noise during start-up...??
So on Friday my new engine install was completed. We attempted to start the car and realized that the old starter was bad due to attempting to start the car with a locked down engine. Replaced the starter and battery on Saturday and got her running. The issue is that during start up, there is this awful sound that seems to be coming from the starter... Once the car is started... everything is smooth and correct.
I purchased the starter from O'Reilly's and I am wondering if anyone else has noticed this before... or received a bad starter from O'Reilly's??? I may just have to pull the starter and bench test to see what it sounds like off the car..
Other than that... my new engine and clutch feel awesome.. waiting till she is broke-in a bit before I drive it too hard..
Pull the starter now! Look at the gear on the starter, is it chewed up? Now look at the ring gear on the flywheel is it chewed up too?
I think your starter is not meshing correctly with the ring gear. Don't start your car any more until you verify the gear on the starter & flywheel are OK. If you chew up the flywheel ring gear the transmission will have to come out to replace it.
You don't hear the noise once it starts because the starter is no longer grinding on the ring gear.
I'd blame the starter & hope you didn't do expensive damage.
Loosened the starter this morning and it has a lot of play.. moved it inward toward the engine. Attempted to start and heard about the same noise as before. Pulled the starter and the gear looks fine... looked that the flywheel... looks fine too.. no marks on either one. Tried to bench test the starter and it was not wanting to turn over. Took it back to O'Reillys and they tested it and found that the solenoid was jumping in and out sporadically...and the computer said that it "passed" ... (haha) He ordered the only 2 in the regional area and they should be in tomorrow. They are going to test them both before I take one.
Hopefully this solves the issue.
squawSkiBum
10-02-2015 09:21 AM
iamcamkeenan
08-10-2015 03:31 PM
