scratching head. "sudden loss of power and oil smell."
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
I have a 2010 mcs with a few modifications. Exhaust, dp, intake, sprintbooster, and wheels. The other day I lost from what I figure is around 20% power. I also started to notice a burning oil smell. It happened within a period of an hour or so. Took my son to his mother's via the interstate, and on the way back.....gone. I had my intake valves cleaned less than 5k ago, and seafoam every 3k. I've heard stories of the valve cover pcv doing this, but is it the most likely culprit? Pulled a code that said it was downstream air leak post maf. Any tips, and has anyone changed valve covers/pcv and fixed this issue?
Think that code has something to do with a vacuum leak. So yes, the valve cover would prolly be the culprit. Are you hearing any kind of hissing after shutting the car off?
No hissing from what I can hear. The typical cool down cycle begins per usual, but no strange noises. I cleared the code around noon here, put 30 miles on and it has yet to show its face again.
It is still low on power. Would plugs make a difference like that and that quickly.?
