R50/53 Hard shifting problems...
'02 R50 with 102k miles.
In the last 10 days I've put about 400 mountain miles on my Mini - two round trips to Boy Scout Camp. Lots of climbing, dropping, up & down shifting.
Since then, here is what I've noticed:
A quick grind when dropping into reverse and a stiffness when shifting - about the last 1" of throw or so.
I've had this car about 17 months. I have no idea when any transmission work may have been done.
Any ideas?
Any ideas?
Mine was humid, but once I removed the rubber boot oil leaked everywhere. But if yours is completely dry I would look elsewhere. Try to put your car in first gear and hold the clutch for a minute or two and rev it after (You must be on a completely flat surface) If your car goes forward a bit than your clutch is not disengaging properly and you have probably have a problem with your Slave or Master.
Other than that it could be your pressure plate that is starting to go but I would look at the easier stuff before getting there.
Grizld700
12-30-2015 10:47 AM
deputydog95
12
09-12-2015 06:49 PM
SneedSpeed
09-02-2015 05:34 AM
