R50/53 BRebels's 2003 MCS "Winston"
Old 04-04-2015, 01:12 PM
BRebels's Avatar
BRebels
BRebels is offline
Couple of weeks ago I purchased "Winston",a BRG/W 2003 MCS with 58k miles.
The car was in very good shape but as with my past car purchases,there's always something that needs fixed/repaired.
So I made an appointment with Ian @ Maitland Importers in Orlando to give the car a "once over" and then I'll be able to figure out a plan of attack and deal with the most crucial repairs first,then begin some mods after.
Power Steering hoses,Ignition Wires,Spark Plugs & Air Filter were replaced.
This week repair: Oil Change with Fumoto Drain Plug
http://www.amazon.com/dp/B004FFLEJW/ref=pe_385040_128020140_TE_3p_dp_1 http://www.amazon.com/dp/B004FFLEJW/ref=pe_385040_128020140_TE_3p_dp_1
& replace Oil Filter Stand Gasket.
After that,the other work will be Front Control Arm Bushings,Engine Mount & replacing Stabilizer Link on Rear Sway Bar.
After discovering that my car was prewired for 6 CD Changer,I decided to pull my Audiovox(DICE) Mediabridge out of my BMW & install it in the Mini.
Rather than run the cable loom to the glovebox,I decided to keep it in the boot.
Here's a short list of things I'd like to do:
-Fender Flare Clips
-Aluminum coolant reservoir
http://www.amazon.com/dp/B00PBTHM4C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=12V8ECE41Q981&coliid=I1E5JVA8ERETD5 http://www.amazon.com/dp/B00PBTHM4C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=12V8ECE41Q981&coliid=I1E5JVA8ERETD5
-Strut Tower Brace
-Rear Sway Bar
-Adjustable Coilover
-Replace Speakers
-W/L OBDII Scan Tool
http://www.amazon.com/dp/B00B3K2X4M/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=12V8ECE41Q981&coliid=I132I9X96BC8ME http://www.amazon.com/dp/B00B3K2X4M/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=12V8ECE41Q981&coliid=I132I9X96BC8ME
-15% SC Pulley http://www.waymotorworks.com/wmw-pulley-package.html
Old 04-06-2015, 03:40 PM
silence2-38554's Avatar
silence2-38554
silence2-38554 is offline
I'm glad you named yours Winston. I originally named mine that, then I decided Baxter was more fitting :-) very curious about your audiovox setup. Will check this out for sure!
Old 04-06-2015, 04:49 PM
BRebels's Avatar
BRebels
BRebels is offline
It really is a great way to integrate into your car's existing system.
And the price is not too shabby.
Old 04-07-2015, 12:17 PM
BRebels's Avatar
BRebels
BRebels is offline
Today's appointment: Oil change. Swap Oil Pan Drain Plug with a Fumoto Drain Valve BRebels's 2003 MCS "Winston"-ojjwmnx.jpg
and replace the Oil Filter Housing Gasket.
Old 04-08-2015, 06:51 AM
InhumanElmo's Avatar
InhumanElmo
InhumanElmo is offline
Nice car! Mine is pretty similar (minus the lights). Also have a pretty similar list of things to do! Good luck and can't wait to see progress.
Old 04-09-2015, 05:19 AM
BRebels's Avatar
BRebels
BRebels is offline
Forgot to mention..Crankcase filled with Liqui Moly 5w-30.
Old 04-09-2015, 06:58 AM
JABowders's Avatar
JABowders
JABowders is offline
Welcome to the MINIacs!
I see you have already working your short list.
Enjoy... I look forward to seeing what you do next.
Motor on!
Old 04-09-2015, 10:17 AM
BRebels's Avatar
BRebels
BRebels is offline
Thanks JABowders!
Really enjoy learning about this car and once I take care of the belts,hoses & fluids,then I can relax a bit & feel more confident in taking a long road trip.
Old 04-26-2015, 05:06 AM
BRebels's Avatar
BRebels
BRebels is offline
Recently had the following work done after I noticed the coolant reservoir had developed a leak.
-Asked that they replace they replace the Thermostat. Good idea,because they found it stuck open.
-Had them change out Coolant System Connectors.
-Replaced the Coolant Reservoir.
Oh & the CV Joint Boot (Left) was replaced after the mechanic noticed it had started to tear.
Old 04-26-2015, 05:40 AM
BRebels's Avatar
BRebels
BRebels is offline
Tired of the blank emblem badge,added a vinyl replacement.
Going to add a lil bit of black paint to fill in the gap between the vinyl and emblem badge
Old 09-03-2015, 10:33 AM
BRebels's Avatar
BRebels
BRebels is offline
Been awhile since my last post.
Here's some additional work that I had completed(work done at Maitland Importers):
-Replaced Engine Mount(right side)
-Replaced Rear Wheel Bearing
-Replaced Front Control Arm Bushings(Powerflex)
Also swung by AutoGeek in Stuart,FL to pick up some detailing supplies.
Wolfgang Uber Compound
Wolfgang Finishing Glaze
Wolfgang Deep Gloss Paint Sealant
Sonax Full Effect Wheel Cleaner
Pinnacle Polishing Pad Cleaner
Cobra Guzzler: 16"x24" & 20"x40"
6 Gold Plush jr Micro Fiber towels 16"x16"
Lake County Flat Pads( 2:Black,2:Orange,2:White)
Old 09-03-2015, 10:43 AM
Spencer Roper's Avatar
Spencer Roper
Spencer Roper is offline
Loving the BRG!
Sounds like you've made some excellent progress
Your list of detailing supplies is quite comprehensive as well. Have you done much detailing work ?
I'd be interested in seeing some pictures of your process.
Old 09-03-2015, 10:52 AM
BRebels's Avatar
BRebels
BRebels is offline
Originally Posted by Spencer Roper
Loving the BRG!
Thanks!
P.O. left some pretty bad swirls on the hood.
When I arrived at Autogeek,they came out to my car and took a look at the paint & advised me what pad and product combo to use.
I'm probably going to tackle the detailing in 2 weeks.I'll post pics when I do.
Old 09-03-2015, 11:50 AM
Spencer Roper
Originally Posted by BRebels
Thanks!
That'd be fantastic!
I've been dying to figure out how to give my Mini that show car shine
Old 09-03-2015, 03:33 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is offline
Vendor
Powerflex, nice choice! Good luck with the detail. Looking forward to the after pictures. Don't forget to take some good shots of the paint before to compare once you're done. It's always pretty eyeopening seeing how dramatically a good polish and wax can bring your paint back to life, especially living in a place like Florida!
888.280.7799 | 6am - 5pm PST
Old 07-18-2017, 02:34 PM
BRebels's Avatar
BRebels
BRebels is offline
UPDATE:
Been a while since my last post.
Since then I have purchased a house downtown Orlando. The bad news is that due to HORRIBLE traffic & the stop and go which has made my knee sore daily,I am looking at selling "Winston".
If anyone is interested in a relatively low mileage Mini let me know. I'm looking at selling it fairly low as I just don't have the additional space.
I will post in the classified section soon.
Old 07-18-2017, 04:23 PM
Cenla Mini's Avatar
Cenla Mini
Cenla Mini is offline
Automatic or standard?
Old 07-18-2017, 06:05 PM
BRebels's Avatar
BRebels
BRebels is offline
Standard / Manual.
wildwestrider
12-27-2015 08:20 PM
USA-RET
11-09-2015 07:27 PM
dscott90000
09-09-2015 07:55 AM
schwac2
09-03-2015 08:56 PM
doug5g
09-02-2015 04:53 PM
Quick Reply: R50/53 BRebels's 2003 MCS "Winston"
