How To OctaneGuy: Magnaflow Exhaust Install on 2010 Clubman S
Old 01-31-2011, 12:17 AM
OctaneGuy's Avatar
OctaneGuy
OctaneGuy is offline
I purchased a Magnaflow exhaust for my 2010 Clubman S and documented the install. It wasn't a difficult install, though it still took me about 3 hours using all the best tools for an exhaust install including a lift and air tools! As with all DIY articles, I'm glad to help you if you encounter problems, but I cannot accept any responsibility if you mess things up, or otherwise hurt yourself because you read my writeup on how I installed my own exhaust. One more disclaimer. I am not a mechanic, so there might be better ways to do an exhaust install. This is just how I did mine.
So the first thing I did was to take out all the items from the box and make sure all the parts were there. I laid out the exhaust on the floor to get an idea how things go together. I also compared it to the stock install. There are 4 clamps included and you need to make one cut. Use whatever tool you want, I have an air powered saw. I used a coarse blade. I needed 10mm, 13mm, 15mm sockets.
Here is my Clubbie in my shop on my lift.
From below you can see the stock exhaust
From the side of the car, look for the catalytic converter
Here it is
Using a tape measure, measure 3 inches back from the weld line
Mark it with a Sharpie
Using my air saw
Once it cut through the exhaust, cutting was easy.
After cutting for several minutes and cutting almost all the way through, I decided to loosen and remove the support plate.
I've got an air ratchet for this
There are 6 bolts to remove. For me this middle one needed a wrench due to my lift support being in the way
To finish the cutting of my exhaust, I used a hacksaw
Now it's cut (sorry for the blur)
The only other disconnection to make is on the rear hangers. I found removing the nuts that hold the rear hangers in place the easiest way to do this.
With them removed, the whole exhaust could be pulled out
Here is what it looks like with the exhaust removed
Now just put the pieces together, put the clamps on first, and check the orientation so you can easily tighten them later. Leave all the clamps loose so you can adjust the tips.
To protect the finish on the tips, I left the bubble wrap in place
I slipped on the rubber hanger assembly. Some WD-40 can help here.
Then I put it into place and fastened the nuts
Close up of the hangers
Repeat on the other side
Check everything and tighten
All done!
The instructions recommend pulling the battery before the install to reset the computer. The install wasn't difficult but since I did this alone it was a bit time consuming. Hope you found this writeup useful!
Richard Lin
Old 01-31-2011, 06:24 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
That system looks remarkable on the Clubman Richard ! Damn tips were made for it
I'm dying to hear this btw
Old 01-31-2011, 07:22 AM
Bigprfed22's Avatar
Bigprfed22
Bigprfed22 is offline
Sweet look! im digging the big tips. I am dissapointer however in the fact that you did correct the paint under the vehicle... lol
Old 01-31-2011, 12:24 PM
OctaneGuy's Avatar
OctaneGuy
Thanks! I agree! As for the sound, here are some clips. Put on some headphones or on high quality speakers, the difference is substantial. On my MacBook Pro, the sound differences are subtle, but I pipe my audio into an Airport Express here in the shop hooked to a stereo system and the deep rumble sounds amazing, lol.
I stood the same distance behind the exhaust for each clip and was recorded using the Voice Memo function on my iPhone 3GS.
Stock Exhaust at Idle
Magnaflow at Idle very first startup with engine cold
Magnaflow at Idle after a couple minutes
Enjoy!
Richard
Old 02-03-2011, 11:26 PM
djdraddy's Avatar
djdraddy
djdraddy is offline
Hey Rich,
Good Job, Great write-up!!! Typical Octane Guy stuff... Thanks, I'm happy now!
BTW, can you tell me how the stock exhaust tips are fastened to the muffler pipe extensions? There seems to be a set screw of some kind. Thanks again!
Dan
Old 02-03-2011, 11:43 PM
OctaneGuy's Avatar
OctaneGuy
Heh heh, you're welcome!
I'll have to take a closer look but yeah, according to this pic on the far right, there appears to be a set screw.
Originally Posted by djdraddy
Hey Rich,
Dan
Old 02-04-2011, 09:36 PM
OctaneGuy's Avatar
OctaneGuy
The exhaust tips are held on with a 3mm hex screw. Just unscrew it and the tips come off.
Hey Rich,
Dan
Old 02-04-2011, 11:49 PM
djdraddy's Avatar
djdraddy
djdraddy is offline
Thanks Rich. Exactly what I wanted to know.
Dan
Old 02-04-2011, 11:53 PM
OctaneGuy's Avatar
OctaneGuy
You're welcome!
Dan
Old 02-13-2011, 03:17 PM
LiL Stinker's Avatar
LiL Stinker
LiL Stinker is offline
I also put a Magnaflow system on my Laurel Clubman. But I had to do it on my back with the car on jack stands.
Old 02-23-2011, 03:24 AM
razorfish228's Avatar
razorfish228
razorfish228 is offline
How did you connect the part where you cut? Did you weld it back or is it connected with a tube that is larger in diameter with a clamp of some sort?
Old 02-23-2011, 09:05 AM
OctaneGuy's Avatar
OctaneGuy
Hmm, not sure why I didn't document that, but yes, it comes with clamps you slip over the connection points and just tighten the bolts. Very simple.
Old 02-23-2011, 10:03 AM
djdraddy's Avatar
djdraddy
djdraddy is offline
You're just getting old Rich, first thing to go is attention to detail.
Old 02-23-2011, 10:26 AM
razorfish228
Thanks for the reply. I was thinking to myself that this was the most important step is to figure out how to put the new exhaust back on the part that you cut. If you didn't cut 3 inches from the weld than what would have happened? That would have been a mess if you made a mistake in length I am assuming.
It was a really nice writeup. How's the actual sound during driving. I would hate to be on a long trip with it being too loud to hear myself or the music. I have a 2011 Clubman S and I think the interior noise is a bit loud on long trips. I'm comparing to my old C-Class which was so quiet inside until you really hit the acceleration hard.
Old 02-23-2011, 10:37 AM
OctaneGuy's Avatar
OctaneGuy
The clamps just need to hold the existing pipe and the new pipe and if your cut is less than 3inches, say 2.5 or probably even 2 inches you should still be fine. I don't think the distance is that critical as you do have some adjustment still with the sleeve/clamp. I have a photo of that sleeve portion that I didn't post.
There is drone when I'm in Sport Mode and on the freeway. I tend to drive in non sport mode on the freeway, when I don't need the lightning quick throttle response, and prefer to save gas by lowering the revs, and this in turn keeps the drone away.
The reasons to do an exhaust are for the sound and additional modest power gains....if you just want better looking tips, don't change the exhaust..find tips you like and get them welded on.
With my intake and exhaust, it all sounds aggressive when I'm on the gas..the way I like it, but it's quiet and subdued when I'm just cruising around. The sound at idle is much deeper than stock...I like it.
Richard
Old 02-23-2011, 11:03 AM
OctaneGuy's Avatar
OctaneGuy
Haha I don't disagree, lol.
Old 03-02-2011, 05:37 AM
BoCRon's Avatar
BoCRon
BoCRon is offline
Thanks for the writeup and the sound clips. I have spent the last day listening to exhausts . The Magnaflow is my front runner currently. I don't actually take delivery of my new MCS for a couple more weeks so I am still debating. I may just wait until I go to the Dragon and listen to as many as I can in person before deciding. I like the Alta, too.
Oh, and Richard, Thanks for the help on the detailing order. I received everything and have set up my detailing corner in my garage. I'm sure you'll be hearing from me the first time I get out the PC .
Annette
Old 03-02-2011, 08:09 AM
OctaneGuy's Avatar
OctaneGuy
Hi Annette!
You're welcome! The whole exhaust research can be daunting. Really as you're thinking, the best thing is to listen to them in person and decide. There is no hurry to change over from the factory one, lol.
re:
Order and help
Absolutely! Glad to be able to help you! And certainly call me up when you start polishing.
Richard
Annette
Old 03-02-2011, 08:15 AM
Bigprfed22's Avatar
Bigprfed22
I alway find myself looking at you clubbys bum in this thread... Looks mighty good lol
Old 05-26-2011, 04:11 PM
1825vine's Avatar
1825vine
1825vine is offline
Hi Richard,
What kind of air intake do you have? Thanks.
Old 07-04-2011, 11:15 PM
Kitti's Avatar
Kitti
Kitti is offline
After u install the exhaust. Do it show a check engine light?
Old 07-04-2011, 11:57 PM
OctaneGuy's Avatar
OctaneGuy
Nope, no CEL. Still running great!
Richard
Old 07-05-2011, 07:36 AM
Kitti's Avatar
Kitti
Kitti is offline
Thanks Richard. But I read in the detail of the exhaust the pipe it's just 2.25 not 2.5. Is it the same size of oem?
Old 03-29-2012, 01:03 PM
Rusnak_322's Avatar
Rusnak_322
Rusnak_322 is offline
Richard
I know that this post is a year old, but do you have a tune on the car? If no, how does sport mode change the drone or gas mileage? I am looking to put a exhaust on and want to avoid the drone
Old 03-29-2012, 07:45 PM
hamptup's Avatar
hamptup
hamptup is offline
This!
Any interior sound clips at all ranges of driving?
Sexual Chocolate
03-31-2019 08:02 PM
squawSkiBum
10-02-2015 09:21 AM
Longjas
08-24-2015 06:06 AM
08-12-2015 01:24 PM
Quick Reply: How To OctaneGuy: Magnaflow Exhaust Install on 2010 Clubman S
