Removing the boot handle
Old Dec 6, 2007 | 07:27 PM
FP's Avatar
FP
I search but could not find a 'How To' on removing the boot handle. Does anyone have instructions on this?
Old Dec 6, 2007 | 07:46 PM
ScottRiqui's Avatar
ScottRiqui
If you look at the underside of the handle, there are a few torx fasteners. Remove those, and the handle comes right off. There's an electrical socket you'll have to unplug to separate the boot handle's wiring from the car's wiring in order to completely remove the handle.
The only potentially tricky part is that the wires leading to the electrical connection aren't very long on the car side, so you might have to wiggle your fingers into the opening in the car's body in order to re-connect the electrical plug. On some cars I've seen, there's been enough wiring to pull the plug completely outside the car to re-attach it, while on others, I've had to re-connect the plug using needle-nose pliers since the wires were so short.
Old Dec 6, 2007 | 07:53 PM
FP's Avatar
FP
Thanks for the help.
Old Dec 7, 2007 | 05:12 PM
chpsk8's Avatar
chpsk8
I had to pull off the inner panel to get my hands on that plug. I rerouted it to give me a couple inches to work with the next time I take it off.
Old Dec 7, 2007 | 07:08 PM
ScottRiqui's Avatar
ScottRiqui
Glad it all worked out, and that you were able to give yourself more room to work for next time.
Old Dec 7, 2007 | 09:25 PM
Yucca Patrol's Avatar
Yucca Patrol
Me too, but it is easy. Just a few screws and a good solid yank gets it off.
Old Dec 8, 2007 | 09:03 AM
DixonL2's Avatar
DixonL2
While you're in there, you may want to waterproof your microswitch... search on "boonk" for a fun story and solution to my "hatch opens itself" issue:
https://www.northamericanmotoring.co...ighlight=boonk
It's also a good time to clean everything...
Old Jan 12, 2008 | 09:53 PM
shanek's Avatar
shanek
How does the electrical plug become disconnected? It seems tricky?
Old Jan 12, 2008 | 11:33 PM
rkw's Avatar
rkw
It should be obvious once you look at it. Just pull the male/female connector pieces apart. I think the pieces lock together and you have to press a tab to release them.
Old Jan 13, 2008 | 09:04 AM
shanek's Avatar
shanek
Ya, I tried pressing down the tab but it still didn't come off. Guess I will have to try again. I didn't want to break the connector.
Old Jan 13, 2008 | 11:24 AM
DixonL2's Avatar
DixonL2
IIRC a little press on the top unlocks the bottom, or else it's a break-the-fingernail-then-realize -a -small -screwdriver -would've -done -the -trick job.
Still no boonk on my car... :D
Old Jan 15, 2008 | 07:58 AM
HWY129's Avatar
HWY129
I haven't been able to find a vendor with a chrome boot handle to replace the red one on my R56 MINI. Anyone have any sources?
Old Jan 15, 2008 | 09:52 AM
rkw's Avatar
rkw
Get it from your dealer. It looks like part# 51132753603 : http://www.realoem.com/bmw/showparts...71&hg=51&fg=95
Old Apr 3, 2010 | 12:48 PM
MrT's Avatar
MrT
how to disconnect the wires?
I'm having a hard time disconnecting the wire hardness. Any pics on how to do this. I've try pressing down to disconnect the pieces, but no luck. Any help would be great, trying to plasti-dip it.
Old Jul 24, 2020 | 08:07 AM
Michael-Mini's Avatar
Michael-Mini
I just tried replacing the boot handle on my 2006 R53. The wires appear to be hard wired to original handle (no plastic connector). Has anyone every encountered this?
greekzilla
Aug 23, 2015 03:44 PM
speedbird_1
Aug 15, 2015 04:44 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
