Electrical Coding cruise control retrofit with NCS expert?
Old 09-30-2016, 07:00 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
anyone coded bc1 to enable MFSW/cruise control?
I just finished my wiring/control/clockspring retrofit now I need to code the ECU, hoping I can do this with NCS expert
Old 10-12-2016, 01:56 PM
gpwpat's Avatar
gpwpat
gpwpat is offline
where did you get the wire? I have had it on backorder for months?
Old 10-12-2016, 02:24 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
ECS tuning I think? I order most OEM from them
Old 11-22-2016, 09:24 AM
gpwpat's Avatar
gpwpat
gpwpat is offline
So my wire showed up. I have all the parts to install now. Just having trouble refinishing the steering wheel pieces. whatever. I thought I would never see the wire. Were you able to get it programmed via NCS expert? or did you have to go to the dealer?
Old 11-22-2016, 09:29 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
pin 101 on my ecu is already occupied by something else so I stopped there and never found out how to continue
Old 11-22-2016, 02:58 PM
gpwpat's Avatar
gpwpat
gpwpat is offline
Hmm, not good. My car has crono pack. all the retrofit instructions use regular speedo. I wonder how that will affect my retrofit?
Old 11-22-2016, 04:16 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
both clusters are canbus it's just a parameter that the kombi module uses, I dont think that'll be an issue
I think facelift have slightly different wiring and I'm not sure what to do next
Old 11-26-2016, 08:27 AM
gpwpat's Avatar
gpwpat
gpwpat is offline
I checked my plug at the black plug. The one in the car is green. And all the wires need to be swapped. The 2 pins are free. I have it all sorted out except the facelift clutch switch. The directions I have are in German and there is already a clutch switch on the clutch master cylinder. I might just use the pre facelift switch and build my own bracket to trigger it. My old prefacelift car which has cruise control doesn't have a clutch switch but does have a sensor on the master cylinder. So confused.
Old 11-26-2016, 09:38 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
Can you send me the directions you found? I think existing clutch wire can be tapped no need to run the fusebox lines
Old 12-09-2016, 11:46 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
ista/p has a retrofit function, I was able to code my car last night
Jarvistech
R55 :: Clubman Talk (2008+)
16
04-08-2017 03:02 PM
guka747
09-28-2016 01:54 PM
RichHasty
09-25-2016 05:48 PM
zman70
09-10-2016 02:26 PM
50shadesofr53
09-08-2016 06:29 AM
Quick Reply: Electrical Coding cruise control retrofit with NCS expert?
