Cooper (non S) Modifications specific to the MINI Cooper (R50).
drivetrain question any info is appreciated
Old 10-17-2016, 04:58 PM
1slowR50's Avatar
1slowR50
1slowR50 is offline
I'm converting my non s 5 speed to a 6 speed my question is it possible to use the R50 flywheel and pressure plate and use a r53 clutch disk now i know that the r50 disk is 200mm and the r53 is 215mm but has anyone bothered to look into it ?
Old 10-19-2016, 12:54 AM
chris.j.lamb's Avatar
chris.j.lamb
chris.j.lamb is offline
I do not think that would be a good combination because the OE R53 clutch driveplate is solid and if you put that on a solid R50 flywheel there would be NO driveline damping at all...... so lots of NVH & would probably destroy the Getrag gearbox.....
Old 10-19-2016, 08:31 AM
1slowR50's Avatar
1slowR50
1slowR50 is offline
are those gear boxes really that sensitive ? I have another "non mini" car that's making 600+ solid plates and disks on a stock gear box that that are known for going bad been driving on for a few years now.
im not looking to make cazy power or anything the mini is my daily im just wondering if I can get away with just swapping the disk and trans
Old 10-25-2016, 10:03 AM
ganue's Avatar
ganue
ganue is offline
Key question - Midlands or Getrag 5 speed is you starting point???
Old 10-25-2016, 10:11 AM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
I'd first try comparing part numbers.
Go to OEM parts and they'll have them listed.
http://www.realoem.com/bmw/enUS/select
Scroll down the 'Series' window and select the models.
Old 11-03-2016, 01:08 PM
Dennis Bratland's Avatar
Dennis Bratland
Dennis Bratland is offline
If it's Midlands, the bolt pattern doesn't match. You need all-R53 parts from the flywheel back. Either the OEM dual mass and matching clutch, or else a matching aftermarket version -- best bet is the Valeo.
I don't know about Getrag.
Old 12-03-2016, 04:41 AM
daviday's Avatar
daviday
daviday is offline
This should help if you haven't already seen it. I attempted this when my throwout bearing blew itself apart. I ended up replacing the clutch kit as theres a handful of little parts that are needed to make it work properly.
https://web.archive.org/web/20150404...heWeakLink.pdf
Old 12-04-2016, 06:30 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
NO you need a cooper S clutch and flywheel to make it work. We have done more of these conversions than anyone and it is really nice when done.
We just use the valeo kit as it is cost effective and has all you need.
https://www.waymotorworks.com/valeo-...l-kit-r53.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
RudeJoe
10-17-2016 08:32 AM
sawdustman
09-15-2016 02:57 PM
jmedina94
09-15-2016 12:12 AM
flatlander_48
09-05-2016 02:20 PM
sparkyj
08-10-2016 05:54 PM
Quick Reply: drivetrain question any info is appreciated
