Gearbox grind putting it in Reverse
It's been about 9 months since I had a rebuilt gearbox put into my MkII, and it recently seems to have developed a grind when I try to put it in reverse while the engine is running. Sometimes putting it in neutral, and pumping the clutch pedal will solve it, and it goes in smoothly. It could be my imagination (I hadn't driven it for a month while away), but it seems the it's much stiffer going into the other gears, as well, but no grind at all. What are some things that I could be checking before doing the long drive to the Mini mechanic? Thanks for any info.
Mine started doing this, I bled it and it would be fine for a bit then get worse again, but it never leaked a drop, and as I had already rebuilt both the master and slave cylinders I was at a loss. Finally replaced the slave with a new one - problem solved. Oh, and I depress the pedal, I don't peddle my car! :-)
I still don't understand how it can suck air and not leak fluid, but there you go.
If you don't have any fluid on your pedal, the linkage or the carpet under the clutch pedal, it's probably the slave.
The reason it doesn't grind in the forward gears is that you have synchros on them - wears the synchros mightily tho.
it could be a Clutch master or slave cylinder weeping.......to check the master for leaks you will need to put your hand up inside the by brake pedal and use a strong torch you will see where the brake and clutch pedal attach ti the cylinder put hand in recess and feel the bottom of the clutch to pedal pivot pin if wet then your clutch master need new seals.......also look a slave and feel round rubber boot for fluid........
BoCRon
08-17-2015 01:21 PM
