Creaking Sound when Depressing Brake Pedal
Old Apr 28, 2025 | 06:57 PM
Brickalicek's Avatar
Brickalicek
Hey everyone,
I’ve got a new development on my F56. Depressing the brake pedal creates this creaking/clicking sound. See the video, I think it should be pretty audible.
The sound seems to come from the middle/rear, but I’m not confident in that.
Any thoughts? Has anyone run into this before? When driving the brakes seem to function just as well as ever, and no codes about needing to change pads.
File Type: mov
Old May 2, 2025 | 11:38 AM
WhatV8's Avatar
WhatV8
If that sound is inside the cabin, then check the pedal hinge bushings. If that sound is from one of the wheels, I would make sure your slide pins are not seizing up so the caliper can self-center itself. That is where I would start.
Old Jun 20, 2025 | 03:26 PM
Brickalicek
thanks. Checked the slide pins, they were fine.
I put the pads back in with some brake grease and it went away. Came back several days later just as loud. It’s odd. It’s like the brake pads are sticking.
Old Jun 23, 2025 | 10:24 AM
WhatV8's Avatar
WhatV8
Is there some corrosion built up on the caliper/bracket that the pads ride against? If so, you may need to wire wheel/abrasive clean those areas, so the pads can more freely move back and forth. I have had to clean off the pad contact surfaces each time I have replaced my pads, but I live in the rust belt and the car is a DD.
Old Dec 11, 2025 | 12:22 PM
Hudbli's Avatar
Hudbli
Did you figure out what it was? Think I’ve got the same issue on my cooper s
oldkid6
May 21, 2024 11:08 AM
mwayne5
F54 :: Clubman Talk (2015+)
Nov 14, 2022 12:23 PM
F56-JCDub
Jul 31, 2021 06:01 PM
013
Feb 4, 2020 07:50 AM
115hp
Tires, Wheels, & Brakes
Apr 7, 2006 04:31 PM
