Buying a set of 2022 JCW 18" takeoffs
Old Mar 14, 2022 | 12:56 PM
ironhead3fan's Avatar
ironhead3fan
Thinking of buying a set of 2022 Cooper JCW 18" takeoff wheels with tires. Wheels are in perfect condition with the factory Pirelli tires. Question is, do I have to pair up the TPMS sensors from these new wheels or will my 2022 Cooper JCW recognize them automatically? Thanks.
Old Mar 14, 2022 | 04:08 PM
steelrat's Avatar
steelrat
If it's like the 2019 when I put my snows on this year, the car detected the change and took me right to the tpms screen in the menu. It basically ran a recalibrate, and was good to go. When I go back to the summers (eventually) I assume it will follow the same process.
The snows are on factory 16" rims.... so I assume the tps are there. But I haven't had any reason to actually get a low reading. I guess I could go outside to freeze and read the actual, pressures. <G>
Old Mar 14, 2022 | 05:32 PM
ironhead3fan
You can bet your Mini would have told you if the sensors were not there and should have been. Thanks for the info!
Old Mar 14, 2022 | 08:49 PM
dpcompt's Avatar
dpcompt
Can you run 16" rims on a F56 JCW?
Old Mar 16, 2022 | 04:44 PM
steelrat's Avatar
steelrat
I don't think so, that's how I got my snows....... The original owner was saying he was getting a jcw and they wouldn't fit....
Old Aug 30, 2022 | 05:03 PM
steelrat's Avatar
steelrat
Just to close the loop with anybody who is searching.
I recently had to replace all four tires, because of a sidewall damage. I can confirm there was no sensors inside my wheels. The system in the car still works fine....
Old Aug 30, 2022 | 05:45 PM
dpcompt's Avatar
dpcompt
No sensors?????????
Maybe the "S" is different than my JCW, but there are sensors on my wheels (they are attached to the valve stem and require a battery to be replaced over time). When I rotate my tires, I have to go through a procedure to reprogram the sensors.
Old Sep 1, 2022 | 12:18 PM
TVPostSound's Avatar
TVPostSound
The battery in a TPMS is not replaceable. I dont need a procedure when rotating.
They all are part of the valve stem.
Old Sep 4, 2022 | 11:44 AM
steelrat's Avatar
steelrat
It could be a us vs can too.... All I know, is my factory wheels didn't have a sensor and I was surprised too.
Old Sep 6, 2022 | 06:49 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Canadian models use the wheel speed sensors to implement a "flat tire monitoring system" instead of using individual TPMS sensors in the valve stems. It makes winter tire/wheel changeover so much easier. I live in YOW btw.
tom.moran
Jun 21, 2017 08:27 AM
03cooperr53
Jan 21, 2016 02:09 PM
coop4me
May 22, 2014 08:42 AM
mcar00
Tires, Wheels, & Brakes
Sep 27, 2010 11:19 AM
