GFB Now @ ECS Tuning
N14 Motors:
GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles.
The solenoid coil itself from the factory-fitted valve is great- the ECU opens it faster than any pneumatic valve so why replace it? The weak point however, is the valve mechanism itself. GFB’s DV+ solves this problem by replacing the valve parts with an anodized billet aluminium housing, fitted with a brass piston machined to exacting tolerances.
N18 Motors:
New to GFB’s ground- breaking DV+ range is the T9353, which is designed to fit in the tight confines of the MINI N18 engine bay. Less space surrounding the factory diverter valve on the N18 engine means the current MINI DV+ (Part T9352) cannot be used. Instead, the T9353 kit splits the DV+ into two parts, the valve, and the solenoid, (which are joined by hoses), meaning the solenoid can be mounted lower in the engine bay out of the way.
Fits: N14 Motors
R56 MINI Cooper S (2007-2010) JCW (2009-2012)
R55 MINI Clubman S (2008-2010) JCW (2009-2012)
R57 MINI Cooper Convertible S (2007-2010) JCW (2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE for the N14 Motors!
Fits: N18 Motors
R56 MINI Cooper S (2011+) JCW (2013+)*
R55 MINI Clubman S (2011+) JCW (2013+)*
R57 MINI Cooper Convertible S (2011+) JCW (2013+)*
R58 MINI Coupe' S (2012+) JCW (2013+)*
R59 MINI Roadster S (2012+) JCW (2013+)*
R60 MINI Countryman S/SX(All4)/JCW (2011+)*
R61 MINI Paceman S/SX(All4)/JCW (2013+)*
*Automatic transmissions
Click HERE for the N18 Motors!
N14 Motors:
N18 Motors:
Fits: N14 Motors
Fits: N18 Motors
cargusjoh
R55 :: Clubman Talk (2008+)
Mar 17, 2016 12:18 PM
