:: ECS Tuning :: Fumoto Drain Valves // ECS Wheel Bolts // JCW GP2 Belly Pan Kits
Old May 1, 2014 | 02:28 PM
R50 R52 R53 GEN1 Fumoto Oil Drain Valve
The Fumoto 14mm oil drain valve replaces your OE drain plug for fast, easy oil changes.
Includes a threaded brass extension for oil pans with recessed drain plugs. The Fumoto oil drain valve features a ball valve with tight tolerances to ensure it will not leak once lubricated. Initially, you may wish to use a pair of pliers or a glove to turn the valve, as the valve will be stiff until lubricated during the first oil change.
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
[B]Click HERE for the MINI Fumoto valve
MINI R61 Paceman ECS Stainless Brake Rotor Set Screw
Have you ever tried to remove the brake rotor set screws on your MINI?
If they are showing signs of corrosion, a failed attempt at removing may result in a screw that needs to be drilled out.
ECS Tuning is proud to introduce our very own solution to this problem. We have designed a stainless steel rotor set screw that will not seize up! Because of its stainless steel composition, our set screws will be easy to remove for years of trouble free use, unlike the OEM part.
Made from stainless steel. No more seizing.
Fits :
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for ECS SS Rotor screws or for more information.
R55 R56 R57 R58 R59 Wheel Bolts
Weathered or damaged lug bolts can detract significantly from your MINI's curb appeal. Worn bolt heads also present the risk of stripping when attempting wheel removal, making changing wheels or tires a headache.
ECS offers exact direct-fit wheel bolt replacements for your MINI; choose from black-zinc or silver coating - both are corrosive resistant, OEM-quality sets.
Fits MINI:
R56 Cooper /S/JCW (2007+)
R55 Clubman /S/JCW (2008+)
R57 Cooper Convertible /S/JCW (2009+)
R58 Coupe' /S/JCW (2012+)
R59 Roadster /S/JCW (2012+)
Click HERE for ECS Wheel Bolt kits or for more information.
MINI R52 Headlight Restoration Kit
The SYLVANIA Headlight Restoration Kit contains everything you need to restore your headlight lenses to their original condition:
1 Oz. Surface Activator
½ Oz. Clarifying Compound
1 Oz. UV-Blocking Clear Coat
Waterproof Premium Sandpaper (400, 1000, and 2000 grit)
Applicator and Polish Cloths
Protective Tape
Vinyl Glove
Fits MINI:
R52 Cooper Convertible S / JCW ( 2005-2008 )
Click HERE for Sylvania Headlight restore kit or for more information.
MINI GEN2 GP2 Belly Pan Kit
Genuine GP2 Parts are always welcomed premium, performance-enhancing additions to your MINI.
The aerodynamic, heat-dispersing Belly Pan Kit for your Gen 2 MINI was engineered for more aggressive, sportier driving - Air ducts direct air to critical engine and drivetrain components, while the structural-fiber woven plastic compliments the underside of your car perfectly.
The Genuine MINI GP2 Belly Pan Kit also includes pre-installed speed screws, holding washers, and all necessary hardware for installation.
GP2 Genuine
Fits MINI:
R58 Coupe /S/JCW (2012+)
Click HERE for JCW GP2 Belly Pan kit or for more information.
R60 R61 Schwaben Oil Filter Socket
Instead of using damaging and ineffective pliers or wrenches to grapple with your oil filter housing, pick up the right tool for the job and focus your efforts on loftier pursuits.
The Schwaben 27mm hex socket fits 1/2" drive ratchets and allows for an effortless, non-marring removal of your Oil Filter Housing.
Made of chrome vanadium steel, this dedicated tool will compliment any MINI owner's toolbox.
Fits
R60 Countryman /S/SX/JCW (2011+)
R61 Paceman /S/SX/JCW (2013+)
Click HERE for Schwaben Socket or for more information.
Jan 4, 2019 12:51 PM
papawhiskey
Aug 10, 2015 09:31 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
