Cost Effective Diagnosis Tool from WMW
Old Mar 18, 2014 | 08:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works has one of the coolest and most cost effective diagnosis tools available. This Easy Diag tool is a simple bluetooth plug that connects to the OBDII connector. After you hook it up you connect via bluetooth to either an Apple product Ipod, Ipad, Iphone or Android device. Then you simply can read codes, clear codes, or read data streams. But not just in the DME, you can also do ABS, Airbag, Body modules, Heating, A/C, and more.
After you get the tool you will have to go online and register it and download the app to use it. Then you will have to download the specific MINI software for $40. After that just start your diagnosis. There is NO LIMIT on the number of cars you can use it on. And you can download software to do diagnosis on any other make of car for an additional $40 per make of car. Making this the most cost effective tool to read and clear codes. We've found using it from the Ipad to be really simple.
Here is a screenshot of all the modules you can connect to on the R50 R52 R53 MINIs.
And this is a screenshot of an R56 showing all the modules you can use it on
Start your Diagnosis today with the Easy Diag Tool, and save the expensive dealer cost to clear a simple fault.
patsum
26
May 29, 2021 06:29 PM
Oct 19, 2015 08:07 PM
Joeygonz
Oct 2, 2015 11:24 AM
rlp
Sep 11, 2015 03:28 PM
Suspension Products
Sep 10, 2015 11:46 AM
