Helix will be back at MOTD 12, doing installs, service, parts and vehicle coding (see this link for an intro to vehicle coding). We can now code F56 Series cars along with Gen 1 and Gen 2 cars. Here's the list of codes we can do for your F-Series cars.
Aside from the advanced coding, each code is just $20, with a maximum of $60 if you want multiple codes. There may be more, so don't hesitate to stop by the Helix tent to inquire. Stay tuned to this thread for more info in the coming weeks, and we'll see you down there!
Here are just some of the coding options for the R Series Cars:
Popular Coding Options for (2007-2013) Rxx Mini Coopers
Car Access Module
Close Windows & Sunroof w/ Lock on Key Fob
Auto Unlock Doors When Key Is Removed
Activate Panic Alarm **Needs factory alarm installed
Maintain Power Windows Operation For 60 Seconds After Switching Off Ignition
Selective Unlocking With Key Fob
Roof Module
One Touch Sunroof Operation
Navigation Module
Enable Weather-Band Radio
Remove Legal Disclaimers
Instrument Cluster Module
Disable Corrected Speed Reading (Both Digital and Analog)
Disable Key-In Gong / Door Open Reminder **Hit or miss with some models
Always Display Digital Speed In Cluster
Efficient Dynamics Shift Suggestion Indicator
Disable Road Freeze Temperature Warning (Gong at 37 Degrees)
Airbag Module
Disable Driver’s And/Or Passenger’s Seat Belt Reminders
Footwell Module (Light Module)
Fogs Come On With Parking Lights / Headlights (Disables Toggle Switch)
Fogs Stay On With High Beams
Fogs Stay On When High Beams Are Flashed
Windows DO NOT Stop Rolling Up When Door Opened
Euro Hazards (Double Blinking)
Euro Hazards with Ignition Off and On
Disable Bulb Checks for following circuits:
Low Beams
High Beams
License Plate
Front and Rear Fog Lights
Corner Lights
Parking Lights
Daytime Running Lights
Brake Lights & Signal Lights
Welcome Lights Activated for following circuits:
Front High Beams
Front Low Beams
Rear Fog Light
Rear Turn Signals
Front Turn Signals
License Plate Lamps
Climate Control Module
Disable A/C Engagement When Selecting Auto Mode
Power Steering Module
Torque Steer Fix
Retrofit Coding
-Halogen to Xenon Conversion
-Bluetooth
-OEM Alarm System
-Sirius Radio
-Retrofit Power Fold Mirrors
-Sports Seat Retrofit
-Adaptive Headlight Failure
-Remove/add Fog Lights
-Aux Input
-Disable PDC sensors
-PDC Disable for Factory Hitch and Trailor Module
-Rear View Camera retrofit
-LCI Taillight Coding
Options may or may not be available depending on chassis and model year. If you do not see an option on this list you are interested in, please feel free to ask!
Oh, and sorry for the slow responses, everybody: I had surgery Monday AM and have been laid up and whacked on Percocet. I'm going to try to make it to Helix Tomorrow and catch up. Meanwhile, if anybody has scheduling questions for the Dragon, call Helix and talk to Ryan or Brandon in the office.
