What size tires do you have on your 17x7.5 wheels?
Old Apr 12, 2007 | 07:53 AM
  #26
curv872's Avatar
curv872
Originally Posted by minihune
235/40-17 tires are designed to fit rims 8-9.5" wide. Using 17x8 rims or wider would be best. 17x7.5 is a narrow rim to use, you'll loose a little tire width as a result.
FYI - The OEM setup for my 1995 BMW M3 comes with 235/40/17 mounted on 7.5" Motorsport Wheels.
Old Apr 18, 2007 | 12:11 PM
  #27
jymontoya's Avatar
jymontoya
With my experience with 235's, as long as you're not lowered more than .75" 235's should fit without rubbing. Of course this depends on your offset, but that's another story, isn't it.
Old Aug 22, 2007 | 11:58 PM
  #28
howsoonisnow1985's Avatar
howsoonisnow1985
Originally Posted by Hangin'_with_Mr.Cooper
Excellent, and thanks! I was really leaning towards the 215/45....also I'm helping my friend pick out wheels/tires...so this help goes to him as well.
So what about the offset? What is the highest offset you can have on a 17x7.5" w/o rubbing with both stock or H-sports? If anyone knows?
BTW, I currently have 18x7.5" with 215/35 on stock suspension...with either a full tank of gas or someone in the rear seat, I can sometimes get rubbing...but it's nothing that has ever damaged the tire or affected my driving.
"So what about the offset? What is the highest offset you can have on a 17x7.5" w/o rubbing with H-sports? If anyone knows?"
I HAVE THIS VERY SAME QUESTION!!
Can I run a 17x7.5 with 37 offset?? (on 215/40-17 rubber)
Old Aug 23, 2007 | 03:38 PM
  #29
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
There is a range of offsets that would likely work.
Best is to be conservative and not at the limits. Wheel offset determines how far inward or outward the wheel rim sits in the wheel well on the hub and there are slight differences for front and rear wheels. If you know someone that has a wheel that fits that helps.
When you change and upgrade suspensions you can affect clearance especially if you lower your MINI. The lower you go the less the clearance.
Sometimes a rear swaybar if too square in design will hit, sometimes the lower rear trailing arm which is standard on all MINIs.
The tire width also is a factor when going wider than stock 205mm as is the tire height when going taller than stock 24.3". You get much less clearance.
For a stock MINI with stock suspension and stock sized tires using 17x7 or 17x7.5" rims you can use wheel offsets of about +37mm to +48mm. Safer would be +42 to +45mm.
When you lower your MINI you have a smaller range and +42mm to +45mm tends to be OK. As the width of the rim gets wider then the offset gets less and the wheel tends to stick out of the wheel wells more (fender doesn't cover the tire). 15x8" usually with +33 to +36mm offset for lowered MINI.
Old Feb 22, 2010 | 08:29 PM
  #30
eric loe's Avatar
eric loe
It seems 215/4517 tire cost less than 205/4517 tire. I am currently using toyo proxes4 205/4517. Dry handling is good but i notice hydroplanning on speed above 65 mph. Proxes4 also comes in 215 and its even cheaper. Do you think using 215 will help a bit on the hydroplanning?
Old Feb 23, 2010 | 03:43 AM
  #31
howsoonisnow1985
In theory...no. Wider tire generally gives better contact patch thus grip on dry roads, but in rain a wider contact patch acts like a boat. But 205 to 215 I doubt anyone would notice the difference.
In 215/45-17 an excellent rain tire is the Goodyear Eagle F1 Asymmetric probably the best rain tire and also very good in dry. And its like $492 after rebate at Tire Rack.
In 215/40-17 there is the Michelin Pilot Exalto PE2 that is also a excellent rain tire and very good in the dry for $446 after rebate at Tire Rack.
Old Feb 23, 2010 | 09:32 PM
  #32
eric loe's Avatar
eric loe
Thx for the input. I notice those two tires have treadwear of only 240 but i doubt they have excellent grip and really good track tires. However for daily use i dont think i will do much track time. i use my mini mostly for hwy commute so i will most likely pick tire that will last. The treadwear on my proxes4 is 300. I have used it at least 25000 miles and i think i still have abt 15000 miles to go. All in all, i think i ll just stick with 205 since tire will weigh less than 215 and having 215 wont help in wet condition either. I think i will just stick with proxes4 cause they look good and seems to last.
Old Feb 23, 2010 | 11:15 PM
  #33
howsoonisnow1985
I never said they have excellent overall or dry grip, I said they have excellent superior and the best rain grip and ultimate hydroplane resistance of any tire and very good dry grip, which is what you were asking for in your original post. The two tires I mentioned are NOT by any means a track tire btw. Extreme Summer Tires treadwear run between 140-200 and track tires 30-100 treadwear.
Old Feb 26, 2010 | 11:00 AM
  #34
strshp's Avatar
strshp
Following the thread and thinking about the conversations with Dan at Fast Mini. He states without hestitation, 235/40 17 will fit on a a 7.5" wheel. I can find no one in the SF Bay area who will install them for me. Tire Rack was very discouraging. Sounds like a sweet look, but if I can't get them installed, then no dice. Right now I am with what appears to be the majority here, 215/45 17's on the 7.5" rims with45mm offset. Comments?
Old Feb 26, 2010 | 03:03 PM
  #35
Alex@tirerack's Avatar
Alex@tirerack
Most 235/40/17 mounting ranges are from 8"-9.5" . Many users will mount tires below mounting range, the only ramification is the tire's tendency to wander or follow pavement contours - tramlining.
I can mount and ship you a set if you need them, but there will be "condidions" on recourse on this type of user accepted fitment.
Let me know
Old Feb 26, 2010 | 05:17 PM
  #36
strshp's Avatar
strshp
Alex
Thank you. Unfortunately you guys don't have the wheels I want. I did an order today for the Rota RB's in gunmetal/polished from Fast Mini 17 x 7.5. The more I thought about it, I was concerned about tramling. Think I will go with the 215/45's. Will cruise your site to see what you have and maybe look at the Toyos's as well. Don't think I have seen them on your site.
Old Feb 26, 2010 | 06:07 PM
  #37
howsoonisnow1985
Do you have a R53 or R56?
If you got a R56 Yes depending on offset.
On R53 No unless you're willing to dremmel and do some "flattening" of metal. See threads below.
If you are going that size I suppose it is for max grip, hope you take full advantage and get a sticky tires like: Dunlop Direzza Sport Z1 Star Spec, Nitto NT05, Bridgestone Potenza RE-11, Toyo Proxes R1R or Yokohama ADVAN Neova AD08.
More info re: R53:
https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/85646-project-235-40-17-a.html
AND
https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/80271-235-40-17-on-17x8-42-a.html
I seen the R53s at A&E Performance in Campbell running 7.5 wheels with PS2s 235/40-17. I asked them about it they said they had to dremel moulding though. Did not ask about offset.
And both cars I seen were running Michelin PS2s.
Originally Posted by onasled
Front trimming was easy. Trimmed a good amount of the outside of the plastic wheel well and trimmed some of the inner lip off the arches. The rear was a bit more work. Trimmed away the outer part of the plastic wells, cut off some of the plastic well mounting studs, ground away what I could of the outer edge of the metal fender and then banged it out a bit with a hammer. Trimmed away the inner lip of the plastic arch and had to trim some of the backside of the arch to fit perfectly over the now slightly faired out fender. This may all sound like a lot but it was pretty easy to do and completely un-noticeable when all was done, unless it was studied by a sharp eye. Spacers were used, 5mm front and rear to clear the front struts and the rear trailing arm.
Car was lowered maybe 1.5" on PSS9s.
Wheel offset was +45.
The tires I ran with this setup were the Toyo RA1s, 235-40-17s, shaved and full tread, and the Hoosier rains, 225-45-17. The Hoosiers are actually a bit wider.
Old Feb 27, 2010 | 11:58 AM
  #38
strshp's Avatar
strshp
It is an R56 Clubman S. If it that much trouble to put the 235's on, I will definitely stick at 215
Old Mar 1, 2010 | 10:18 AM
  #39
howsoonisnow1985
No trouble is with R53
Old Nov 2, 2024 | 04:47 PM
  #40
ttypeguy's Avatar
ttypeguy
01 Bonneville ssei 17x7.5
235/55zr17 factory here
kazyn
Oct 25, 2019 02:34 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Edgar78
Aug 15, 2015 05:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
