215/40/17 fitting?
Old Apr 18, 2003 | 11:56 AM
6f7's Avatar
6f7
I want to get the TD PRO RACE 1 17x7 +45. Should get the 205/45/17's or 215/40/17 yoko avs? Will the wider tire rub? 10mm doesn't seem like much of a difference, but I want to be 100% certain that I won't have issues.
Old Apr 18, 2003 | 12:04 PM
nfo's Avatar
nfo
i'm sure you'll be fine.
there are a bunch of people who have fitted 215/40's.
Old Apr 18, 2003 | 12:12 PM
bbmykal's Avatar
bbmykal
That's what I have and like it. I may eventually lower it as well.
Old Apr 18, 2003 | 12:15 PM
bbmykal's Avatar
bbmykal
Whoops, 205/40/17's. But Gabe has the 215's and they look tough, and have no problems at all.
Old Apr 18, 2003 | 12:27 PM
6f7's Avatar
6f7
Great, thanks for the quick response, as usual!
Alex/Tire Rack, can you confirm this?
_________________
Old Apr 18, 2003 | 01:50 PM
Alex@tirerack's Avatar
Alex@tirerack
TireRack does not guarantee 215/40/17 as it has a shorter diameter, and needs 35-36 psi to maintain correct load. I know several MC drivers using this size with good results, and no complications.
Alex
Old Apr 18, 2003 | 01:54 PM
d-mini-ero's Avatar
d-mini-ero
I have 215/45-17 and have no issues...
I will probably not be able to lower the car with this setup, but have no intention to do so.
Peace,
D
Old Apr 18, 2003 | 03:54 PM
6f7's Avatar
6f7
If there are no issues what are the pro's and con's of the two sizes? Is there any difference at all? Thanks for all your help!
EDIT: I think I'll just stick to the recommended 205/45/17 and save myself from potential issues with the diameter being too small.
_________________
Old Apr 21, 2003 | 10:11 PM
asaulo1's Avatar
asaulo1
I run 215/40/17s on my 17 x 7 wheel with no issues... In fact, I've had 2 200+ lb passengers in the back and there was no rubbing at all... go for it:smile:
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
