changing front rotors + pads?
Old Jun 28, 2006 | 10:39 AM
Bugs's Avatar
Bugs
what is the difficulty of this task?
Ive been told the rears can be a big pain in the azz.. but what about the fronts?
What all tools are needed?
i need to do mine ASAP.
Also, if anyone has part number for the brembo oem replacments, that would rock
Old Jul 2, 2006 | 03:12 PM
ony1952's Avatar
ony1952
Btdt
I recently changed the pads on the front of my JB/JB '03 MCS. I found it easy. My only concern was the two allen head bolts that hold the caliper. The bolts are inserted into a bushing allowing the tips of the bolts to press against the back of the break pads. I conferred with a BMW certified wrench who gave me the OK on the servicing.
Old Jul 3, 2006 | 09:52 AM
moreorless's Avatar
moreorless
Fronts are very simple. Nothing special.
Rears are a bit trickier in that as you clamp the piston to retract it back into the caliper, you MUST rotate the piston as well. But it's not really that hard. A simple C-clamp to clamp and either channel locks (slip joint) or needle nose to rotate. 'tis not a big deal.
In my opinion, the hardest part is removing the Torx screw holding the rotor onto the hub. Make sure you get that bugger out before you take off the calipers!
...Les
Old Jul 3, 2006 | 10:18 AM
PSYCMINI's Avatar
PSYCMINI
I bought a pair of Brembo cross drilled slotted off ebay. I think they are stock replacement they modified, cost $100 shipped. Now i am stuck on which pads to get.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
FLYM1N1
Aug 15, 2015 11:20 AM
