Factory brake fluid
Old Mar 13, 2006 | 10:15 PM
impulse's Avatar
impulse
Factory brake fluid
Does anyone know what the dry and wet boiling points are of the DOT 4 brake fluid that is installed in new cars at the factory? Also do dealers use the same when replacing?
Ben
Old Mar 13, 2006 | 10:41 PM
Motor On's Avatar
Motor On
It makes sense that the dealers would use the same thing, any DOT 4 is good, infact the cap specifies to use ONLY DOT 4 fluid. I don't know the specific temps, but any DOT 4 should do fine unless you are a full time racer.
Old Mar 14, 2006 | 05:21 AM
Minvader's Avatar
Minvader
Hey look - it's the 3 of us who want to replace our brake fluid this weekend, all in the same place! Let us know if you will have some spare time Ben... probably Sunday from the looks of things.
Old Mar 14, 2006 | 06:07 AM
polmear's Avatar
polmear
Ben
some info here:
www.shotimes.com/SHO3brakefluid.html
and links galore here:
http://msxml.excite.com/info.xcite/s...iling%2Bpoints
Old Mar 14, 2006 | 06:42 AM
meb's Avatar
meb
If you are tracking your car - even once - try DOT Super 4 or Non-silicon DOT 5. These two are really one and the same. They're bioling points are very close to Silicon based DOT 5.
Motul is one such example
Old Mar 14, 2006 | 09:45 PM
impulse's Avatar
impulse
thanks
Thanks for the replys guys but my original question is still unanswered. I would like to know the specs on the factory supplied fluid so I could compare products. I called a dealer service dept and got "I have no idea" as an answer. Great links polmear. Meb the non silicone is DOT 5.1.
Ben
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
