Batmini + pypz mounted.
Old Mar 10, 2006 | 06:32 PM
  #26
Sam's Avatar
Sam
[quote=Wagnbat]Ok. I like em. I'm thinking big brakes & painted calipers firstquote]
TCE will be at the Dragon as a vendor - will have DragonSpecials - but no installs
Old Mar 11, 2006 | 01:29 AM
  #27
Wagnbat's Avatar
Wagnbat
Thanks for all the compliments, suggestions, and opinions all.
Originally Posted by nealj
Get rings quickly. It's just unsafe without them. You could overstress the lugs which could, in the extreme case, cause them to shear or just cause extra vibration - which you are already experiencing.
Roger. I won't drive until I get the rings, except for emergencies. Also reminds me, I think I stripped a lug bolt they sent me. It has a huge hex key instead of the 17mm Mini bolt head... I'm wondering if maybe it's softer than the Mini oem bolts, and can't take the 88ft lbs.
Originally Posted by krut
uhm.. Currys might have some hubcentric rings for you if you need them asap. I can call and check fo ryou.
Wheels look nice. How's that pulley?
Might they have metal rings? If you could check for me, that would be keen. And the pulley is nice.
I can do tinted reflectors, dunno about the taillights. I've not seen any I like recently...
I do want a BBK now... And maybe some black rotors.
I've considered dropping it for a while, but I don't want to scrape, which I did consistently in my 96 Camaro RS.
Wife said "After the pulley you're done right?".
Heh. Time for some more creative negotiations.
Old Mar 11, 2006 | 06:41 AM
  #28
Krut's Avatar
Krut
your mom's european tail lamps look cool .....
Old Mar 11, 2006 | 02:30 PM
  #29
kenchan's Avatar
kenchan
Originally Posted by ScuderiaMini
wowww, those rims need the biggest BBK possible .
yep, but a drop would be the first step, i suppose.
Old Mar 11, 2006 | 02:51 PM
  #30
ScuderiaMini's Avatar
ScuderiaMini
yep, one leads to another
Old Mar 11, 2006 | 03:11 PM
  #31
MSFITOY's Avatar
MSFITOY
Repeat after me..."Yes Honey...the pulley is all I need."
After the pulley install..."Honey, it's come to my attention that reenforcing the suspension and brakes are needed for safety reasons as the extra power is causing the Mini to go into turns much faster than I'd imagined!"
Old Mar 11, 2006 | 04:00 PM
  #32
kenchan's Avatar
kenchan
^^ im still waiting for the rear diffuser...
Old Mar 11, 2006 | 04:42 PM
  #33
MSFITOY's Avatar
MSFITOY
Me dux
Old Mar 11, 2006 | 04:53 PM
  #34
rhawth99's Avatar
rhawth99
What are these rings that everyone is mentioning? Do they go between the wheel and the rotor and sit around the hub? Anyone have pics? Thanks, just got my first set of Kazera wheels for our MINIs to use as spares and I'm wondering if it is something I need. Wheel size is the standard 16x7 with 45 mm offset.
Old Mar 11, 2006 | 05:06 PM
  #35
mdsbrain's Avatar
mdsbrain
Man your wheels are hot
Old Mar 11, 2006 | 06:01 PM
  #36
ScuderiaMini
what diffuser? Ken, lemme see lemme see
Old Mar 11, 2006 | 06:03 PM
  #37
tattman23
I could be mistaken, but my Married Guy Radar told me that Ken meant he is waiting for the right "opportunity" to explain the benefits of a diffuser to his S.O. I knew I shoulda married a car-girl, dang it .
Tatt
Old Mar 11, 2006 | 06:11 PM
  #38
ScuderiaMini
thanks Tatt.... should have known better. Ken Ken Ken
Old Mar 17, 2006 | 08:22 AM
  #39
Wagnbat's Avatar
Wagnbat
Update:
Called the company I bought them from, Automotive Sounds in Petersburg VA, and they worked to get everything fixed. They called the provider and had them send me new and MUCH better lugs... These are torx style, instead of the 15mm hex key style... And plastic 56.1mm-73mm hub rings.
Everything went on in a snap, no stripping, and no more wobble/vibration in the wheel. Everything is golden with the new wheels. Hope to have new pics up by the end of this weekend.
Old Mar 17, 2006 | 08:32 AM
  #40
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
If you want metal rings, discount tire has them in that size (same size a TDR PR1's).
http://www.discounttire.com/dtcs/home.do
I think mine were, 15.00 shipped?
The problem is that they are anodized pink/red.
Old Mar 17, 2006 | 08:33 AM
  #41
62Lincoln's Avatar
62Lincoln
Bat, this is gonna look great with the BBK (from your other thread). Another vote for lowering that baby asap. Take a look in my gallery for at least an approximation of what to expect.
Cool wheels!
Old Mar 17, 2006 | 08:36 AM
  #42
tattman23
Update:
Kewl they fixed you up . Motor on, vibration-free!
Tatt
  #43
Wagnbat's Avatar
Wagnbat
Thanks for the tip golden_child... I may order a set just in case...
And I am working on lowering the Mini... Just need to decide on which springs I'm going to get. Wife has already approved it.
Old Mar 17, 2006 | 09:21 AM
  #44
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Wagnbat: Go with the Al hubrings. Remember to ask for black, or silver otherwise they will ship you pink (not red!) ones. Fortunately you have to look hard to see that mine are pink. They are a better long term solution over the plastic ones, especially if you ever take your wheels off.
cheers, phil
Old Mar 17, 2006 | 09:45 AM
  #45
The MINITOR's Avatar
The MINITOR
Good wife
Old Mar 22, 2006 | 10:48 PM
  #46
1QKMNIS's Avatar
1QKMNIS
Gorgeous
Man, those are fantastic! I have been looking for a good 5-Spoke with a chrome lip! My god these are perfect....mind if I be a mooch and get myself a set as well? Once again looks good, with a drop like everyone else has recommended you'll have a beauty......well more beautiful
freeman727
Dec 10, 2017 04:00 AM
freckles81
Jan 15, 2017 06:33 AM
BenjiFace
Dec 20, 2015 06:56 AM
Finhead
Aug 20, 2015 08:40 AM
Wagnbat
MINIs and Minis for Sale (archive)
11
Apr 29, 2007 08:41 PM
