hubcentric rings - how tight a fit is right?
Originally Posted by mmatarella
OK, my wheels arrived with the plastic rings way back when, I had expected metal. But I went ahead and all was OK. The metal ones showed up two days later.
I will switch to the metal rings when I rotate shortly. I got metal hub rings and also round 'spring' wire rings. Do the wire rings go in the wheel first or after the hubcentric ring. I assume they either a spacer if first or a retainer if last?
Alex
Mini'mon
Aug 16, 2015 04:15 PM
