hoping they'll fit!
Old Mar 7, 2005 | 09:45 PM
misifoota's Avatar
misifoota
hoping they'll fit!
I have some Brembo's from my husband's totaled Evolution... I am trying to figure out if they will fit on my '03 MCS... Here are the specs on the brakes:
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, front: 320mm dia. rotor,
4-piston calipers
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, rear: 300mm dia. rotor,
2-piston calipers
I currently have my stock 17" S-lites on my MCS. Just by looking, I am thinking that I will need a deeper offset wheel, but as I've never dealt with wheels/brakes before, I could use some input, and maybe even some recommendations as to what wheels/wheel specs to go with? Thanks!!
Old Mar 8, 2005 | 05:02 AM
onasled's Avatar
onasled
I would highly doubt that they will even come close to fitting. You night be able to use the front rotors and the calipers, but you will need new hats and an adapter for the caliper. No way for the rear without some custom mods, and then you will have no e-brake.
Best would be to call Brembo.
Old Mar 8, 2005 | 06:07 AM
RedBaronF2001's Avatar
RedBaronF2001
Are you talking about the OE Brembo's off an EVO? If so - forget it. Different bolt pattern, caliper brackets, etc.
Sell those and buy some MINI specific brakes.
4-piston calipers
2-piston calipers
Old Mar 8, 2005 | 06:15 AM
misifoota's Avatar
misifoota
didn't know about all those specifics. thanks!
Old Mar 8, 2005 | 10:48 AM
Alex@tirerack's Avatar
Alex@tirerack
A larger rotor diameter allows the calipert to be pulled back off the rotor hat. I have so many wheels that will clear big brake mitsu's -caliper and rotor is good, but caliper position's requirment reduce available to about 5-7% of what should fit.
Dont run Mitsu big brakes.
Alex
Old Mar 8, 2005 | 08:04 PM
2perCooper's Avatar
2perCooper
4-piston calipers
2-piston calipers
if you are selling the rear calipers..could you please let me know
TIA
-Chris
Old Mar 8, 2005 | 08:21 PM
misifoota's Avatar
misifoota
i'll be selling absolutely everything off that car that didn't get creamed. :smile:
W0TM8
Dec 19, 2019 07:50 AM
David.R53
Sep 1, 2015 06:49 PM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
mdorn98
Aug 11, 2015 08:49 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
