First Mini, brake question
I hope someone can help. Maybe I'm overreacting or too demanding but I need some advice.
Recently purchased 2019 2 door HT. Brake light indicator noted rear pads need serviced at 11500 miles. Went to my local mechanic who has always served me well. Was told it was too early to need new pads, they then verified the pads weren' ready to be replaced however the brake fluid was low, and they filled it. The pads were worn to a 4. So pads soon but not now. They also advised I take it to the dealer and call MiniUSA because this was too soon and the brake fluid level was questionable. They also suggested the brakes should have a minimum warranty, usually to 12000 miles. I've never had a car need brakes at 12000 miles before so I took their advice.
Made appointment with dealer. Explained the situation. Made it clear going to the dealer was difficult to accomplish because of their hours and I needed to know what they planned to do with a vehicle with the system indicating rear pads service. They said they didn't know until they inspected. I arrived, they saw the light and said you need new brakes. (sigh) No inspection. Wanted me to pay $140 for inspection.
I refused and left very frustrated.
Is this normal behavior from the brakes and the dealer? I love this car.
Cool me off.
Thanks.
Cool me off.
Thanks.
Are you an aggressive driver? The rears on these cars go pretty fast because the system uses the rear brakes automatically to control the car, especially in aggressive driving. I replaced all my brakes at about 16,000 miles. The fronts had plenty of life, the rears still had some time but were worn a lot more than the fronts.
Did you buy this car new or used?
If it is a 2019, I can't believe they threw the diagnostic charge at you, shameful behavior. What crappy dealership was this?
This vehicle is my commuter. All highway, but SoCal highway. Purchased new.
This dealer does seem to be rather crappy. I have had to question their service with MiniUSA in the past. They made some changes after my complaint, but they don't know who made the complaint.
The vehicle was just in for a 10k oil change and check-up, but apparently the brake fluid wasn't checked.
suggestion
learn how to inspect pads yourself . . . then you are less likely to be scammed
requires NO TOOLS for a quick check and just taking off the wheel for a full check (car's jack and wrench)
You can usually see the brake pad thru the wheels of a MINI ..... if you can find the brake assembly looking thru the wheel you are half way home.
If you want part two, just ask . . <or search the other 20 times I've posted it> sorry, I'm grumpy tonight
'teaching' novice MINI DIY folks out of my garage since 2003
for the BASIC question of OP
Our R-59 is approaching 35,000 on original pads ......
A bit unusual IME as I've typically had to do a pad swap before 30,000 <typically around 25k> ... but the 59 is probably lighter . . .
in the OLD days
pads and rotors were covered under pre-paid maintenance ... typically dealers found they needed replacement the first visit OUTSIDE of pre-paid
first time I took my 02 in after pre-paid expired I was told 'new pads and rotors NOW'
funny thing was I'd replaced 'em myself not 2 months earlier . . . .
in the OLD days
I'd CONTACT MINI USA.
I can't imagine how they can justify not looking at a car under warranty with brake warning light on.
Your mileage seems ridiculously low for pads to be worn, and I've never experienced rears wearing before fronts like that, although with all the computerized stuff now, I guess anything is possible.
I'm not a fan of dealer service departments.
jniiiice
05-01-2008 04:17 PM
Drivetrain First post! First MINI! First question! LSD?
redmist
12-18-2006 09:29 PM
