Fender Rolling
Old Aug 27, 2018 | 11:40 AM
Countryman97s's Avatar
Countryman97s
Fender Rolling
So i'm running 8.5 rims on my countryman with a 225 45 18in tire and I am having the issue of rubbing mostly on the back. What are people doing to roll their fenders? Are you trimming them? What is the solution?
Thanks in advance.
Old Aug 27, 2018 | 11:51 AM
MrGrumpy's Avatar
MrGrumpy
Hmmm... interesting, have you lowered it or anything? I’m running the same tire size on the 18” turbofans with no issues at all, plenty of room to spare actually. Even with a wider rim, it looks like there is plenty of space.
Old Aug 27, 2018 | 12:49 PM
Countryman97s
Yeah I have Megan Racing Coils on and lowered it a lot. I used to be much lower but because of the more aggressive offset it rubs slightly
Old Aug 27, 2018 | 01:21 PM
MrGrumpy's Avatar
MrGrumpy
Ahhhh, that explains it. Ok. I don’t know, other than a different offset wheel, but I’m sure somebody here has a solution for you.
It looks great! That’s a really good picture.
Old Aug 27, 2018 | 01:38 PM
bugeye1031's Avatar
bugeye1031
Moderator
I remember seeing someone trim the inner fender (under the arches) someplace....they were installed wider arches/flares. They literally took a grinder to it....with the arches off, of course. If I remember correctly, they were installing the type of arches that had the mounting bolts exposed.
Great looking Countryman!
Old Aug 29, 2018 | 12:15 PM
You will not have to roll the fender ( metal part) unless you trimmed down the plastic fender so much, you have to be pretty much on air and slammed to the ground on a MINI to reach that point or with some huge wheels. On most plastic flares you have about an " or so to you hit the metal body.
AltaMiniS
Mar 3, 2010 06:13 AM
macncheese
Tires, Wheels, & Brakes
14
May 17, 2004 07:22 PM
BSUCardinalfan
Dec 23, 2003 02:14 PM
dominicminicoopers
Mar 6, 2003 10:50 AM
