2012 tpms
Old Aug 8, 2018 | 05:48 PM
AZdsrt's Avatar
AZdsrt
2012 tpms
Have been searching thru threads, nothing stood out. The low tire pressure light went on on our 2012 MCS. When checked, one tire was at 34, all others at 38. I thought, well it isn't all that low. Put in 4 lbs, light stays lit. I suspect one of the TPMS sensors in one of the wheels has either gone bad or the battery gave up. So, I guess the question is, long are the sensor batteries supposed to last?
Old Aug 8, 2018 | 06:08 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I've seen across the board responses on battery length. Our 2011 CM has original sensors, still working. If the battery gave up you would be seeing zero pressure, I would think.
Did you do a reset?
When this happened to my son on the Countryman, turned out he had a very slow leak from a nail.
Old Aug 8, 2018 | 06:26 PM
AZdsrt's Avatar
AZdsrt
How do you do a reset? We're on vacation and don't have the manual with us.
Old Aug 8, 2018 | 06:49 PM
Minnie.the.Moocher
As i recall, stalk button push till settings.
Old Aug 9, 2018 | 05:35 PM
AZdsrt's Avatar
AZdsrt
You were right on Moocher, thank you. My wife drives the Mini, went I got in to do the reset, I noticed the symbol showed which tire had been low. How the heck does it know? I can't imagine the sensor is different in each wheel. Anyways, thanks again for taking the time to respond.
NVmini
Feb 29, 2016 09:07 AM
pidge1114
Jun 16, 2013 12:20 AM
Phx JCW
May 18, 2012 05:17 PM
angryrabbit
Southern California
Feb 28, 2012 02:59 AM
Jun 27, 2011 01:58 PM
