Official F56 Wheel Fitment Thread
Old 03-16-2015, 05:36 AM
VicSkimmr's Avatar
VicSkimmr
VicSkimmr is offline
Originally Posted by G_Russ
I checked with the manufacturer and the rim shop, and they both agreed that my "soon to be" setup is literally the max that could go on the car without modding the flares. I plan to lower the car, but not nearly as low as yours. The potholes in Toronto would wreck the rims and suspension. The rim shop also suggested that 205 tires would also help with the fit.
205/40s are what I was running, it's a good size. A bit of stretch to help with fitment but nothing extreme.
  #152
Old 03-16-2015, 08:03 AM
G_Russ's Avatar
G_Russ
G_Russ is offline
Were you running spacers on your first setup? Is there a particular brand of tire that you'd recommend? I got a good price quote on Yoko S.Drives balanced and mounted, but I'm still shopping around.
  #153
Old 03-16-2015, 09:26 AM
VicSkimmr's Avatar
VicSkimmr
Nope, no spacers. I think I went with S.Drives too, they were pretty decent but I don't have any real recommendations.
  #154
Old 03-22-2015, 12:09 AM
blue al's Avatar
blue al
blue al is offline
Originally Posted by randomquickness
I believe they would be fine as long as the offset isn't too agressive
Thinking in terms of a Et 38 17 x 7.5 rim
Planning on a bbk also at some stage so edging towards the lower Et numbers for clearance
Existing rubber from my R 53
Have some yokohama ad08r in 215/45/17
And winter 225/45/17 (from Audi TT so wide) to throw in the mix
  #155
Old 03-22-2015, 08:49 PM
hemisedan's Avatar
hemisedan
hemisedan is offline
I"ve been wondering just how the 225's would work. I have 205 x 50 x 17's and they just fit. Look really mean on my roadster. Next year will be a factory JCW hatch, so wondering if there is more wheel clearance with the F series.
  #156
Old 03-23-2015, 05:15 AM
randomquickness's Avatar
randomquickness
randomquickness is offline
The wheel specs are fine but i'm betting the 225 will rub slightly on the plastic flares
  #157
Old 03-24-2015, 12:27 PM
VicSkimmr's Avatar
VicSkimmr
I just got an email back from BC, they're going to work on a camber plate system for the F56
  #158
Old 03-25-2015, 04:54 AM
randomquickness
Like separate camber plates? Or coilovers with built in
  #159
Old 03-25-2015, 07:49 AM
VicSkimmr's Avatar
VicSkimmr
Separate. I asked for a price range and they said $195 for the pair.
  #160
Old 03-30-2015, 12:45 PM
blue al's Avatar
blue al
blue al is offline
Any chance these could work with the adjustable OEM dampers
If so I'm in
  #161
Old 03-30-2015, 01:38 PM
VicSkimmr's Avatar
VicSkimmr
I have no idea. I don't even know how the adjustable OEM dampers work actually. If the top mounts of the struts are the same as the non-adjustable version then I'd imagine it would work. The BC coils use the OEM top mounts on the F56 coilovers but I suspect it will be replaced with the camber plates.
You'd have to email them.
  #162
Old 03-31-2015, 01:51 PM
Errie806's Avatar
Errie806
Errie806 is offline
Hi guys. I have the OEM 16" black rims on my 2015 2 Door Hardtop.
I want to know what the best size tire to go with is on these rims without risking rubbing or compromising the drive or odometer accuracy.
Would 215/50/16 be ok? I currently have the 195/55/16 run flats.
I want to just give the car a wider sportier stance with better grip than runflats without altering the suspension.
  #163
Old 04-01-2015, 08:15 AM
VicSkimmr's Avatar
VicSkimmr
So at one point I managed to bend the metal under the front arch while trying to get out of a really crappy driveway and decided to fold it under instead of bending it back into it's original position, and now I've noticed that the arch doesn't sit quite right at that spot anymore.
What that leads me to believe is that we could instead pull the metal away from the wheels even further and end up with an easy way to "pull" the fenders. They're not nearly as rigid as the R56 were, I think they would easily adapt to the metal underneath being pulled. I'm going to test it out next weekend to see.
I haven't checked to see if it would work the same for the rear but I'll take a look while I'm working on the fronts.
  #164
Old 04-01-2015, 08:35 AM
randomquickness
can you snap a couple pics of the process? I may need to go this route when it comes time to go low.
  #165
Old 04-01-2015, 11:11 AM
VicSkimmr's Avatar
VicSkimmr
Yeah for sure. It might not have any effect, there isn't that much metal that could be bent. It's worth a shot though.
  #166
Old 04-07-2015, 05:48 AM
VicSkimmr's Avatar
VicSkimmr
Wheels by jasonwithers, on Flickr
  #167
Old 04-11-2015, 11:28 AM
BFox's Avatar
BFox
BFox is offline
Here is my mini.
  #168
Old 04-11-2015, 11:31 AM
BFox's Avatar
BFox
BFox is offline
One more.
  #169
Old 04-12-2015, 09:04 AM
VicSkimmr's Avatar
VicSkimmr
Looks good! What are the specs on those wheels?
  #170
Old 04-12-2015, 12:47 PM
BFox's Avatar
BFox
BFox is offline
Team dynamics 17x8 et35, on BC coilovers
  #171
Old 04-12-2015, 06:56 PM
randomquickness
^what size tires? any rubbing? I'm running the same spec wheels but with 5mm spacers in the rear.
  #172
Old 04-12-2015, 07:08 PM
BFox's Avatar
BFox
BFox is offline
Stock tires for now 205-45 . Only rubbing is on rear under hard cornering but I haven't done anything to fenders. I want to drop it another 1" but don't know if I want to risk fender damage. Just came back from a trip to California and there roads suck.
  #173
Old 04-13-2015, 06:22 AM
Zillon's Avatar
Zillon
Zillon is offline
Don't come to the northeast, then.
Car looks great, though!
  #174
Old 04-17-2015, 01:51 PM
Selshan's Avatar
Selshan
Selshan is offline
If I wanted to run 17x7.5, ET32 on stock suspension, would I need spacers or would I be able to just bolt up? I'm still not super familiar with how to determine what will fit.
  #175
Old 04-17-2015, 01:56 PM
randomquickness
you will definitely not need spacers. If anything you may get a little tire rub on the fenders depending on the tire size.
Quick Reply: Official F56 Wheel Fitment Thread
