Official F56 Wheel Fitment Thread
  #726
Old 07-05-2016, 11:43 AM
BadakVT's Avatar
BadakVT
BadakVT is offline
Has anybody fitted the 18" NM RSE12 JCW-Spec (ET40, 7.5 width) with a 225/40r18?
Thinking of getting the ET40 version instead of ET45 since I'm planning to retrofit the JCW brakes in the future.
Any problem with rubbing the fender or the shock? I'm lowered on KW V2 but not slammed. Thanks!
  #727
Old 07-05-2016, 06:58 PM
isamin's Avatar
isamin
isamin is offline
Just for comparison I have an R56 JCW (big brake) on ET 45x7.5x17 using 235/40/17 and lowered 2" with no rubbing or scraping. Looks great,rides better.
Hope this helps.
ISAMIN
  #728
Old 07-06-2016, 08:12 AM
ryanschram's Avatar
ryanschram
ryanschram is offline
Hope this helps.
ISAMIN
it doesn't. this is the f56 wheel fitment thread
  #729
Old 07-07-2016, 02:08 AM
cal113's Avatar
cal113
cal113 is offline
Just across this when I was searching some parts for my mini. Read the last line in the 1st photo! And take a look the ET in second photo. So from my understanding, if you are looking to get coilover in the future you must get wheels with ET 40 in order to not use any spacers? Photos are took from NM engineering website. Is this correct?
Attached Thumbnails Official F56 Wheel Fitment Thread-image-1160815080.jpg   Official F56 Wheel Fitment Thread-image-4224815038.jpg
  #730
Old 07-08-2016, 05:09 PM
Kinsey56's Avatar
Kinsey56
Kinsey56 is offline
Originally Posted by Kinsey56
Wheels: AVID.1 AV-52 17x8
Tires: Hankook Concepts V12 215x45x17
Next up lowering springs
Eibachs using my car this week to fit front and rear sway bars, so excited. But anyone know anything about lowering with my offsets? Wheels fit pretty agresively and don't want my fenders getting destroyed by my tires every pothole I hit.
Edit:ET 35
  #731
Old 07-11-2016, 08:43 AM
VicSkimmr's Avatar
VicSkimmr
VicSkimmr is offline
It's a tall tire so I can't really comment. When I was on the same setup I was on 205/40s so my experience probably isn't worth much.
  #732
Old 08-01-2016, 04:08 PM
cal113's Avatar
cal113
cal113 is offline
Hi does anyone know if 18x8 et45 will be a direct fit for f56? Means no need to stretch tire and run negative camber. Thanks!
  #733
Old 08-01-2016, 07:48 PM
02fanatic's Avatar
02fanatic
02fanatic is offline
Depends on tires, suspension, and brakes (JCW or no?)..for my JCW I'd prefer a 7.5" wide wheel as this will give you more space between the tire (if not too wide) and the strut. I believe that the NM Wheels made for the JCW are 7.5" wide with ET 40 or 45, and both fit without spacers (whether you go 17" or 18"). I prefer 18's personally. I've not bought a second set of wheels yet, but when I do I won't be going with an 8" wide wheel...7.5" is plenty even for a wider tire.
  #734
Old 08-02-2016, 02:57 PM
Lucila's Avatar
Lucila
Lucila is offline
When I purchased my car, it came with the standard 16" rims for the MCS. I had the dealer swap them out for the 17" tentacle spoke rims. My question is: how many lbs of air do these require as aposed to the 16" wheels? The tag on my door tells me the spec for the 16" as the car was originally built for the 16" wheels. The 17" wheels came with the Dunlop sport max RT.
  #735
Old 08-02-2016, 10:39 PM
cal113's Avatar
cal113
cal113 is offline
I want to go with 7.5" but the wheel I like only offers 18x8 et45 that's why I want to find out if it will work on my car or not 😭
  #736
Old 08-02-2016, 10:52 PM
cal113's Avatar
cal113
cal113 is offline
Originally Posted by VicSkimmr
Somewhere between 40-45 for an 8" wheel would be good if you're going with a meaty tire. On the stock suspension you won't have to worry about any clearance issues.
would 18x8 et45 clear if i just change the spring? Thanks!
  #737
Old 08-02-2016, 10:55 PM
cal113's Avatar
cal113
cal113 is offline
Originally Posted by oc cj
I'm running a set of avant garde M310s, 18x8 et 45 with 225/40/18s. I'm also lowered on NM springs.
Absolutely no rubbing in the front. Rear rubbed slightly on the inside top of the fender well and the plastic lip that sticks out. I trimmed the plastic and maxed out the camber and no more rubbing.
can we see some pics? i am thinking getting M220 with same spec but according to avant garde, it's a no go on my car
  #738
Old 08-02-2016, 11:19 PM
cal113's Avatar
cal113
cal113 is offline
Very nice .
Hi, does the Avant Garde M220 18x8 et45 will fit on F56 cooper base? Thank you!
  #739
Old 08-05-2016, 04:22 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
About to have this fitted in the morning.
18x8+50
225x40x18
Currently on KwV3
Will try to fit JCW bbk in the future.
Hope this all works. If not, (let's just hope t all works)
  #740
Old 08-05-2016, 04:23 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
It's nice to have found this thread again. Re-Reading the whole thing brought back lots of memories! Lol
  #741
Old 08-05-2016, 04:29 AM
cal113's Avatar
cal113
cal113 is offline
Originally Posted by MiniF55
About to have this fitted in the morning. 18x8+50 225x40x18 Currently on KwV3 Will try to fit JCW bbk in the future. Hope this all works. If not, (let's just hope t all works)
Looking forward to the outcome!!!
  #742
Old 08-05-2016, 04:33 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
lol. Me too cal113 getting anxious.
  #743
Old 08-05-2016, 11:59 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
It's close but fitment is life. Lol.
Ta da!!! No spacers, just right.
  #744
Old 08-05-2016, 01:54 PM
ECSTuning is offline
Received 1,967 Likes on 1,767 Posts
Very close. Well done. You have near zero wheel gap, but just enough. F55 done right.
  #745
Old 08-05-2016, 02:05 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Ecstuning. My guess is 2-3 mm. Couldn't get the gap in he pic, but there is some in there. lol.
  #746
Old 08-05-2016, 02:35 PM
Yea, its pretty low over stock height.
  #747
Old 08-05-2016, 06:27 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Fronts are flush and rear is a little tucked, maybe 5-8 mm.
  #748
Old 08-05-2016, 06:49 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Are they going to clear when you go to the BBK?
  #749
Old 08-05-2016, 07:03 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
I have no idea Vetsvette. Lol. I think I need to save my pennies for a bit before I can even think about more car parts. I'm sure if needed, I can get a 5mm spacer to push he offset +50 to +45. People seems to have found a sweet spot at +45
Didn't really get a good angle, but most likey need 5-8mm spacer to clear jcw bbk. Not sure, or didn't measure at all.
  #750
Old 08-06-2016, 05:31 PM
02fanatic's Avatar
02fanatic
Those wheels will look great with the red Brembos! Very nicely done! Spacers will give you a bit more room from those struts too! :-)
Quick Reply: Official F56 Wheel Fitment Thread
