Run Flat Tires
wise counsel everyone... my mechanic brother just promised me a beating if I used plugger... he said bite the bullet, get some roadside assistance... and that he charges holiday rates ALL the time to family...
And just to confirm, the rim doesn't need to be changed, correct? While the owners manual alludes to the run flat rims being "special" I have never seen anything to support that line. Not like the metric rims of the Mustangs in the 80's that actually were a special diameter and needed special tires.
I am switching to Continental Extreme Contact DWS 205 55 R16's from www.discounttiredirect.com I bought a Mini 'donut spare from Way Motor Works.
I heard that BMW was pressured to put Runflats on the Mini. I am sure it is costing them sales.
Pelican, let us all know how you like those Continentals. I put Nexen's on 225/50/17's I was talked out of the Continentals by the Salesman. So far I have no issues with the Nexens's. I had never heard of them till that day. I have an old BMW 325is that I run Yokohama's on, soft, sticky and excellent on corners but not very good wear life, which I knew when I bought them. I only run the car maybe 3k a year
Installed 205 55 ZR16 Continental Extremecontact DWS 's yesterday. WOW!!!
The ride is great and I still have great steering feedback...maybe better than from the Bridgestone Turanza runflats they replaced. Not super quiet but way quieter than the runflats. They are almost the same size as the 195 55 R16 Bridgetones they replaced;just a tad higher and wider. My best upgrade yet.
I bought a mini compact spare just in case.
While we're on the topic of these tires, I ditched the crummy runflats about three years ago. The car hasn't even accumulated 25,000 miles since the last set and my mechanic is telling me that the tires are unevenly worn on the inner edges. Is this common with MINIs or is the camber out of alignment? I've owned three cars in the past and never had to deal with tire problems like this. Is Sumitomo a bad brand? That was the ONLY size the tire shops in my city had. I will NOT buy Goodyear. They're horrible. If I find BF Goodrich, Michelin or Falken, which would you recommend for the longest lifespan? I don't race my car and am an average driver.
Minis will wear out tires faster than some cars. Front wheel drive,low profile and smaller diameter rims mean the tires get hot and then wear faster. 17inch rims might wear slower.
Extremecontact DWS are made of a more durable material than the DW which is essentially a summer/dry road tire with exceptional stickiness !! The DWS are a winter summer mix and will wear better than the DW. They also do very well in wet and light snowy conditions. For the money I think they are a great choice.
I've always been a Goodyear fan having used them on many vehicles over the course of 40 years. However, I've also been a fan of Goodrich and had good luck with several other brands. I've had BAD luck with Michelins, but you need to actually do a search for real reactions to tires. In other words, opinions posted here are only based on Mini owners. If you go to sites like tirerack.com or mavis.com there are many others with other vehicles that offer opinions. It was there I opted for the Conti's because the tires had extremely great reviews.
As for the argument posted about "smaller" rims, I come from an era when 13" was the standard compact car rim size, 14" for full sized vehicles, and 15" was typically on trucks. THOSE are smaller rims to me!! FRont wheel drive vehicles are typically harder on the fronts but if you rotate the tires periodically the wear should be evenly distributed. And while 25K may seem like the lower end of the spectrum, I would probably attribute that more to the compound of the particular tire, not to the Goodyear brand. That's another topic to study up on. All tires are NOT created equally even within a given brand. Some are designed for stickiness and other to run 50-60K miles. The longer lasting tires generally also ride like rocks and may not do well in rain.
Tire Pressure
I have recently purchased an '05 "S". The car came with run flat originally. Now has regular tires. The door panel has 38psi for the tires.
I have not seen any threads on a different pressure.
Should I still use the recommended pressure of 38psi?
I have an '05 Cabrio S that I'm going to swap out the run flats and I think I'm going to get a spare and keep it available for long trips, standing it in the trunk/behind the seat space or maybe even in the rear seat area. I understand there's a new unit available that actually comes in a bag so you can keep things clean. For short local stuff I can leave it home, but for road trips, it becomes a piece of luggage.
Also got conti extremecontact DWS's. Cannot describe how much I love these tires! The guy at the shop even got really excited about them when I told him I've been waiting forever to be able to get them. the ride is so much quieter, smoother, and the grip is absolutely insane. I look forward to the rain now!
ltjpunk7
Sep 6, 2015 07:32 AM
