15inch on 2012 Cooper S (Spacers)
Old Nov 28, 2013 | 08:49 AM
Kirkz24's Avatar
Kirkz24
Posting this up for a friend of mine.
She has 15 inch mags on her Justa and wants to upgrade to a 2012 Cooper S
She has winter tires and rims purchased from MINI with the tire size 175/65/R15
Can she add spacers to help her? I was not aware that the calipers on the Justa and the S were different sizes. I thought if it fits one, it will fit the other.
Thanks for your help.
Kirk.
Old Nov 29, 2013 | 08:01 PM
mini coop's Avatar
mini coop
The calipers on the 2007 and up base is the same as the 2002-2006 s. What year base Mini does she own? What brand of 15 inch wheel and what offset are your wheels. Are they oem? What does " mag" mean. S calipers are definitely bigger than base mini's. Spacers may help but then depending on the thickness you may need need longer studs. More info is needed. Thanks.
Old Nov 30, 2013 | 03:58 AM
Angib's Avatar
Angib
Beware. The callipers are indeed the same on both cars, but the calliper mounting brackets are different, positioning the calliper further out from the hub to accommodate the S's larger disc.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
reverse01134
Jan 16, 2017 06:37 AM
FrostyFox
Oct 28, 2015 02:06 PM
cjsdad
Aug 11, 2015 08:46 AM
ti22fjc
Aug 9, 2015 05:49 PM
