Rotating my Victoracers?
Old May 12, 2004 | 08:28 AM
paulmon's Avatar
paulmon
First season running R-Comps. Had my first flog of them last weekend. I'm wondering what is the best patern to rotate these? Simple front to back?
What do others do?
Cheers,
Paul
Old May 13, 2004 | 03:52 PM
paulmon's Avatar
paulmon
no one?
Paul
Old May 13, 2004 | 04:10 PM
Motoring's Avatar
Motoring
I move them around front to back and side to side, but always keeping them paired up. (same two tires are always on the same end of the car). I don't worry about rotation direction, although the tread blocks will feather if you always run the on the same side of the car, making them very squirrelly if you forget and switch sides accidentally.
Hope that helps.
Old May 13, 2004 | 04:11 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I have victoracers and plan to rotate them regularly. Probably each day out Autocrossing. With the intent to keep the wear as even as possible.
Since the wear rating is 50 these are not for street use so the 3000 miles before each rotation rule doesn't apply. Do it more often, check for wear that is uneven. Balance the tires and keep the inflation up at correct levels to maximize your contact patch.
What pattern to rotate? Ask alex@tirerack.com and see what he recommends. whether normal four wheel pattern or just front to back.
Here is a good thread on tire rotation in general-
http://forums.vwvortex.com/zerothread?id=974063
Rotation
Comp tire care!
On using victoracers-
V700 care
Have fun.
_________________
Aloha Hawaii
GAT
Oct 21, 2015 02:12 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Norton70
Sep 24, 2015 06:31 AM
rrglo
Sep 22, 2015 10:05 PM
minimofo
Sep 20, 2015 05:17 PM
