Brake warning light & unable to turn off traction control
Old Jul 28, 2013 | 07:11 PM
k_h_d's Avatar
k_h_d
During one run at my autocross today a weird warning came on. It was the BRAKE and then the brake symbol in the center of the tach. When this happened it would not allow me to turn off traction control. From the owners manual the following is a picture of what I think was being shown. Its either one of the two pictures, I think its the one that says worn brake pads but not sure. I checked brake fluid level and all is fine. Brake pads are thicker than half pad. When I check the service info on the OBC for the brakes it says 14,000 miles left on the front and 28,000 miles left on the rear. I have 10,200 miles on the car.
On the second set of 4 runs there was no warning lights and traction control was off like normal.
Would any information be stored to be read with a code reader?
Attached Thumbnails Brake warning light & unable to turn off traction control-screen-shot-2013-07-28-at-9.05.18-pm.jpg   Brake warning light & unable to turn off traction control-screen-shot-2013-07-28-at-9.06.06-pm.jpg
Old Aug 9, 2013 | 08:07 AM
John@ATLMINI's Avatar
John@ATLMINI
I'm not aware of any information being stored to be read later with a code reader. Have you experienced any problems since? During normal driving conditions? I'd seriously consider taking it in under warranty. This is a scary thing to happen so early in the MINI's life.
Old Aug 9, 2013 | 09:04 AM
v10climber's Avatar
v10climber
Never had any issues on our fJCW and we've got hundreds of auto-x runs on it.
Old Aug 9, 2013 | 01:50 PM
k_h_d's Avatar
k_h_d
Its not happened since. The car has been rock solid. I am thinking its just some sensor with a faulty connection or something, possibly the sensor at the brake reservoir. The reservoir is full so I doubt high G turns would set off a low brake fluid warning. If it happens again I will be worried about it but so far 10,500 miles of no problems.
Bennyboy
Aug 18, 2015 07:28 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
