steering vibrating under braking
Old Jul 18, 2013 | 11:37 AM
  #26
martinb's Avatar
martinb
Originally Posted by Helix13mini
Martinb, in the profession, any precision measuring device is called a mic. Nobody says 'test indicator'. Your implication is that I, by not calling it a 'test indicator', am ignorant about brake rotor warping vs. deposit as a cause of pulsation in the steering wheel. This is nonsense.
My comment about the proper name of the measuring device was only to inform. I' have no idea of your experience or knowledge. No offense was intended nor was there any implication that not calling it by the proper name meant you were ignorant about warping vs. contamination.
FYI: In my profession we call it by what it actually is. If we called every precision measuring device a mic, we'd create a lot of confusion. So, they are called specifically what they are.
Old Jul 18, 2013 | 11:46 AM
  #27
cesar418's Avatar
cesar418
Ok, by question is this problem only happens when front rotors are bad, or can it happen because of bad rear rotors too? At 46kmiles i figure ima need front rotors and pads soon, but i just changed the rear brakes 500 miles ago
Old Jul 18, 2013 | 02:17 PM
  #28
martinb's Avatar
martinb
If the problem with the rear rotors is one where the coefficient of friction on the surface of the rotor varies around the rotor (due to contamination or uneven pad material transfer), then you'll likely never know it exists. You won't feel it through the pedal and it won't affect your steering because it's on the rear wheels. It would have to be monumentally bad for you to notice it.
However, if the problem with the rear rotors is that they're warped, you'll likely feel it as a pulsing (to one degree or another) at the pedal.
Old Sep 8, 2013 | 12:04 PM
  #29
cesar418's Avatar
cesar418
So quick update: the front lower control arm bushings were shot, both were replaced and the vibration is gone
Old Sep 8, 2013 | 04:06 PM
  #30
TG.'s Avatar
TG.
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
HaveATank
Sep 4, 2015 08:04 AM
