balancing wheel with rust
I tend not to pay too much attention to the care of my winter rims and was wondering as the rust creeps along if there are balancing issues to consider ?
Generally no.
You can clean the wheels really well and let them dry. Then use a rust remover before storing.
Are your wheels alloy or steel? Alloy you can just polish a little to get off the rust from the wheel hub.
R84 aka Monza wheels with fair bit of curb rash and rust about 2 inch by 1/2 inch.
I don't believe it affects the bead but I probably should remove tire and inspect while treating the rust.
It's really more of a safety issue than cosmetic so if the rim is healthy I can proceed to treat the rust.
Just wondering if anyone has experienced wheel balance issues caused by significant rust in one location ?
I doubt rust is a concern balance wise .... the amount of metal you removed in creating this rash might be. Given that wheel weights added for balance can be a gram or 2, it's possible.
If in doubt, get the wheel balanced - only a few dollars. Better, get the wheel repaired and THEN balanced. You can get just one wheel done ... don't have to do all 4 at a time.....
Spank
11
Apr 9, 2020 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
