advice please 17x8
Old Mar 30, 2012 | 09:32 AM
Adammcs's Avatar
Adammcs
advice please 17x8
hi all im new had my mini a while now and im looking to get some 17x8 et35 calibre vintage wheels for it. Ill be running 205/40/17 tyres but i also have ap racing BBK am i gonna have issues with fitting these wheels? am i going to need spacers? also car lowered on KW v1 coilovers
appreciate any help!! did use search but couldnt find the correct answer
many thanks
Old Mar 30, 2012 | 09:33 AM
Adammcs's Avatar
Adammcs
these are the wheels
http://www.performancealloys.com/whe...s.aspx?id=1183
Old Mar 30, 2012 | 03:48 PM
bluefox280's Avatar
bluefox280
Which platform (R53 or R56)? And what size rotor are the AP Racing BBK?
- Erik
Old Mar 31, 2012 | 12:06 AM
Adammcs's Avatar
Adammcs
It's r53 and these are the brakes I have
http://www.lohen.co.uk/shop/proddeta...ingBigBrakeKit
Old Apr 1, 2012 | 06:12 AM
Adammcs's Avatar
Adammcs
Anyone?
Old Apr 1, 2012 | 08:06 AM
bluefox280's Avatar
bluefox280
You're kinda in a rock and a hard place; AP Racing specifically denotes that the standard 17in wheels won't fit without a spacer.
However, their also noting that most aftermarket 17in wheel will fit; it's like as double standard.
You need to measure the rotor mounting surface of the wheel to the outside edge of the caliper.
Then you need to get a hold of Calibre Wheels and ask the clearance.
Typically an 8in wide wheel with a 35mm offset will clear most BBK's, but you need to double check before you have a set of wheels may not work.
- Erik
Old Apr 1, 2012 | 08:43 AM
Adammcs's Avatar
Adammcs
Ok cool I'll do that was expecting to have run maybe 13mm spacers anyone know who owns this? Kinda look I'm going for
scfiveo
Sep 27, 2019 02:27 PM
rikaro
Nov 24, 2015 02:05 PM
zdw2082
Oct 5, 2015 09:59 AM
bradstyle
Oct 1, 2015 11:15 AM
bahman
Sep 30, 2015 01:59 PM
